Fixing window
Uh, I was trying to fix my window (crank tuns but window doesn't go up) AND NOW I think I made it worse because the window is all the way down and won't go up. What should I do?
Take off your door panel and place your window back on your regulator (the thing that makes your window go up and down). You may have to MacGyver it together as you may have broken the slot where the glass fits. Or get another regulator.
it might have fallen off the regulator, it will either need new clips or a new regulator if any of the parts are broken, they are pretty cheap from honda
Well, today I took the panel off and discovered that the actually crank mechanism is broken, and the wondow fell off its track. IN the process I accidentally made it worse because I unbolted the crank mechanism and now I can't get it back on. I know I definitely won't be able to be driving it around because the window is completely down. I looked on ebay for some kind of window kit, but I couln't find any. (for my application : 89 CIvic Hatchback (2dr))
just buy it new from honda i just replaced mine i think it was $40, and its easy to install just dont forget to remove all the bolts there was one hidden that you have to look for
Morasso
Sep 10, 2009 05:31 AM
i-want-a-crx
Oct 13, 2007 08:41 AM
