which color is the power wire in my FAN RELAY
Old Dec 11, 2005 | 11:12 AM
rolledthatho's Avatar
Default which color is the power wire in my FAN RELAY
i think the sesor on the back of the motor is messed up my fan runs constantly unless i unplug the relay, im gonna find the hot wire and splice into it and run a toggle switch into my car...
but which is the hot wire 89 lx
colors--
blue
black w/ yellow stripe
another black w/ yellow stripe
yellow w/ green stripe
solid black
Old Dec 11, 2005 | 02:51 PM
DaveSmed's Avatar
Default Re: which color is the power wire in my FAN RELAY (rolledthatho)
Just switch the yellow with green stripe to ground. Leave the relay and power wires connected like they are. (You can tap into the yellow/green wire inside the car at the ECU Pin B4.
Old Dec 11, 2005 | 04:38 PM
suspendedHatch's Avatar
You can get a digital voltmeter for less than $15. Take you 10 minutes to learn to use it by reading the instructions. It will change your life.
tallguy21
Lighting
Jul 19, 2013 08:23 AM
Lsweez
Jul 7, 2007 07:32 PM
89hatcher
Aug 25, 2006 10:48 AM
FMIDRC Racer
Aug 27, 2005 12:22 PM
OutLuDeD
Aug 17, 2003 01:13 PM
