Another OBD2-OBD1 Conversion
Old Dec 11, 2005 | 08:54 AM
StreetRacinThug's Avatar
Default Another OBD2-OBD1 Conversion
Well I have looked and looked and most of my answers have been answered thanks to the "Search" button. Well my last questions that haven't seemed to be answered are..
1)Will the only parts I need are the OBD2-A to OBD1 Wiring Harness and a ECU that is P28?
2)Car has Intake, Header, Exhaust, will it be affected better or for worse?
*So far I know it affects better if the ECU is chipped and the car will be tuned.
3)Phearable.net sells them chipped, but is it worth or just getting piece by piece in other places?
My car is a 1997 Honda Civic EX with a D16Y8 with I/H/E. Looking to go all motor and put in D16A1 Pistons to raise compression, and Port and Polish, Camshaft + Camgear, etc. Anyone thanks for your comments in advance and for all the Flammers sorry for bieng a newb Got to start somewhere.
Old Dec 11, 2005 | 09:03 AM
Default Re: Another OBD2-OBD1 Conversion (StreetRacinThug)
2 min bump
Old Dec 11, 2005 | 09:12 AM
99blackcivicSi's Avatar
get a jumper harness and a p28 its the easiest way to go. boomslang makes awesome products thats who's i have used over the years.
as for the single cam all motor, i know nothing about single cams i have never worked with one just yanked them out and threw them away, with all that work i would just toss a GSR in your car and start with that.
btw people don't flame me or bitch at me because i don't like single cams just my way of doing things
Old Dec 11, 2005 | 09:17 AM
Default Re: Another OBD2-OBD1 Conversion (99blackcivicSi)
I thought exactly as you have stated the first thing is to swap into a GSR but money is a issue for me so thats out of the question so I thought of a decent thing and after reading a D Series can be a power punch with little modification. As for the Jumper Harness..What is that? Same thing as the Wiring Harness?
Old Dec 11, 2005 | 09:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacinThug &raquo;</TD></TR><TR><TD CLASS="quote">I thought exactly as you have stated the first thing is to swap into a GSR but money is a issue for me so thats out of the question so I thought of a decent thing and after reading a D Series can be a power punch with little modification. As for the Jumper Harness..What is that? Same thing as the Wiring Harness?</TD></TR></TABLE>
no a jumper harness plugs into where your ECU would plug into and then on the other end you plug the ecu into it, and its done, instant obd1
Old Dec 11, 2005 | 10:23 AM
Ok then now I understand that thanks alot. Already looking into one. Now my choice of ECU, which would be better to get a Chipped P28 or stock P28 and from who?
Old Dec 11, 2005 | 11:36 AM
TTT
Old Dec 12, 2005 | 05:21 AM
TTT Dont know to get a chipped ECU or not....
Old Dec 12, 2005 | 05:53 AM
someone has to have built a y8 all motor on here with good info on ECU's....should i jus buy it chipped?
Old Dec 12, 2005 | 07:38 AM
eg6ajk's Avatar
yes, conversion harness and ECU (does not need to be p28 if chipped)
if its bolt ons stock ecu is fine. If you are going with the NA build up or boost later on its simply more cost effective to go with chipped ECU now and simply have jumper or run a stock or semistock chip.
there is many places (check my sig - shamless plug - I'll try to beat and match any price) other places such as FF-squad (Katman), Kenji are options as well
nels450
Oct 10, 2008 07:59 AM
Robstunner4
Sep 3, 2006 08:09 PM
specv5150
Jun 19, 2005 10:07 AM
ElectronMan
Jun 14, 2002 06:49 PM
