Compression Ratios from LS to LSVTEC
Old Dec 11, 2005 | 07:50 AM
PinkMaggit's Avatar
Default Compression Ratios from LS to LSVTEC
Pistons are meant for straight LS with a 9:1 compression Ratio what would be the Compression Ratio if a VTEC head (pr3) was put on the block leaving the pistons in?
Old Dec 11, 2005 | 11:35 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Compression Ratios from LS to LSVTEC (PinkMaggit)
Check out http://www.c-speedracing.com. They have a compression calculator there.
Old Dec 11, 2005 | 08:43 PM
PinkMaggit's Avatar
looks like compression bump to 9.3 anyone know if this is accurate?
Old Dec 11, 2005 | 09:51 PM
Combustion Contraption's Avatar
Yes.
Old Dec 11, 2005 | 10:56 PM
93EG6SI's Avatar
Default Re: (LsVtec92Hatch)
i heard when doing an LSVtec, stock comp.(9.2:1) bumps to nearly 10:1 w/ a B16 head and a lil over 10:1 w/ a gsr head.
masquzy1080
Nov 23, 2007 08:45 PM
SupaFly_Honda
Feb 10, 2005 11:46 AM
94teg_RS
Sep 13, 2004 05:16 PM
CRneXt
Sep 27, 2003 07:56 AM
