The B-series must go
Frist off have a LS-V
Bottom End
LS block Sleeved
LS crank
Probe LS Rods
Wiseco high comp 86MM Bore pistons
stock oil pan
prodrive oil pump
Top End
B16A head
Ported by alaniz
black nitrate flat vales
supertech springs and retainers
sk2 stage 3 cams
JG Cam gears
Victor X manifold match ported
RPM 70mm Blank Throttle body
SMS Header
GE fuel rail
650 RC injectors
Trans
Type-R Gearing
4.7 final
long first gear
Prodrive drag spool
Tilton Clutch single plate
motor made 260 whp and 171 wtq
in pomona ran 11.35 at 121mph
and more to come
price to come
Modified by N.O.B. at 12:43 PM 12/11/2005
Modified by N.O.B. at 6:34 PM 12/11/2005
Bottom End
LS block Sleeved
LS crank
Probe LS Rods
stock oil pan
prodrive oil pump
Top End
B16A head
Ported by alaniz
sk2 stage 3 cams
JG Cam gears
SMS Header
GE fuel rail
650 RC injectors
Trans
Type-R Gearing
4.7 final
long first gear
Prodrive drag spool
and more to come
price to come
