PR3 and jdm GSR motor
Old Dec 10, 2005 | 08:40 PM
D-series ninja
Guest
Posts: n/a
Default PR3 and jdm GSR motor
so i have heard that if you are running a pr3 (jdm obd1 b16 ecu ) with a GSR motor that you have to run a different dizzy, and run a 2 oxygen sensor setup ? is this always the case?
bc im running a obd1 JDM GSR with a LS dizzy, i had cut off the one leg to make it work ( its hella ghetto i know. but im broke ), ( skunk 2 mani. so im not worried about contolling the secondaries like a GSR manifold ) and will be running a PR3 from a obd1 jdm b16 since my chipped p28 went bad.and am still using a single oxygen sensor on my header. am i gonna be running into problems with this setup ?
Old Dec 10, 2005 | 08:55 PM
D-series ninja
Guest
Posts: n/a
oh and the car is a 94 integra RS . dont know id that makes a difference.
Old Dec 10, 2005 | 09:25 PM
SVOboy's Avatar
Pr3 is obd0 b16 ecu. Yes it does want 2 o2 sensors, but if you get a chipped pw0 or pr3 then you can disable one of them and only use one and be fine.
EDIT: I forgot there was a pr3 that did the Integra RSi/XSi that is obd1, :-(, you'll have conflict with the o2 sensors though.
Old Dec 11, 2005 | 05:25 PM
D-series ninja
Guest
Posts: n/a
Default Re: (SVOboy)
i have heard that the obd1 pr3, and the obd1 p30 are basically the same exact ECU except the pr3 has more agressive ignition/ fuel maps. ? can someone verify this? if so then why would there be conflict with the pr3. when i know a few people who have run the p30 in an obd1 car/setup, and had no problems with just the single 2 wire oxygen sensor on the header?
Old Dec 11, 2005 | 05:28 PM
SVOboy's Avatar
p30 is stocked for one o2 sensor, pr3 for two.
Old Dec 11, 2005 | 07:10 PM
D-series ninja
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">p30 is stocked for one o2 sensor, pr3 for two.</TD></TR></TABLE>
hmm. well, that sucks. looks like ill be wiring in another o2 sensor. anyone know of a way to do that ( like from the cat. or anything ? ) ? or how is it possible to somehow eliminate the secondary w/o having it chipped?
Cole89ef
Apr 11, 2009 08:54 AM
mrflak0
Apr 18, 2008 06:57 PM
Nightkidef9
Aug 6, 2006 07:49 AM
jdmsijdm
Jan 4, 2005 08:45 AM
Mike banX
Jul 26, 2004 02:53 AM
