The first 15 minutes of welding with my Miller Maxstar...
Turned out pretty good I think. I can't post pics unfortunetly, because my camera is being gay. However, for some reason my welds on some sch40 304 with 308l rod are turning out kinda carbonie/gunmetal/black. How can I get those nice gold and clean welds.
Edit: this is the first time I've ever tiged. I'm basically trying to teach my self from the information I find online, and the advice a couple freinds are giving me.
I tried amps from 75-120, and gas from 15-20. I have 1/16 red tungsten, and was using .045 rod.
Any help would be great!
I need a lot more practice...
Modified by Bryson at 9:03 PM 12/10/2005
The dark color usually means its too hot, but could possibly be unsufficient gas coverage. Also...for sch.40 the .045 rod seems awfully small. I like using 3/32 or so. Keep practicing
Kyle
Kyle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueoval557 »</TD></TR><TR><TD CLASS="quote">The dark color usually means its too hot, but could possibly be unsufficient gas coverage. Also...for sch.40 the .045 rod seems awfully small. I like using 3/32 or so. Keep practicing
Kyle</TD></TR></TABLE>
Yeah, I tried to buy the 1/16 rod, but the store was out. I did a search, and it seems like a couple people are using the 3/32 tungsten/rod. I might go ahead and try that out.
Bryson, hit my up on aim
way to hot , and yes it is over heated it turns grayish when you burn out the cromeum i think it is that keeps stainless from rusting
and 3/32 filler and tungsten is to big , stick with 1/16" tungsten , and that .045 rod melts quick so you need to fead it fast , so for you i would go with the 1/16" filler as well ,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondatec38 »</TD></TR><TR><TD CLASS="quote">Glad to see you just got started. I'm still waiting for my 220V outlet plug at work to be installed.
Thanks. I just decided to try it out on the standard 115 in my garage. It did 130amps no problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">
Bryson, hit my up on aim way to hot , and yes it is over heated it turns grayish when you burn out the cromeum i think it is that keeps stainless from rusting and 3/32 filler and tungsten is to big , stick with 1/16" tungsten , and that .045 rod melts quick so you need to fead it fast , so for you i would go with the 1/16" filler as well ,</TD></TR></TABLE>
Yeah, thats what I thought. I'm sick right now, and have finals next week so I don't think I'll be on AIM for a couple of days. I'll get some 1/16" filler in a week or so and keep at it...
</TD></TR></TABLE>Thanks. I just decided to try it out on the standard 115 in my garage. It did 130amps no problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoenixTurboJesse »</TD></TR><TR><TD CLASS="quote">How fast are you moving? gas is alittle low...around 30 is better. </TD></TR></TABLE>
word .. dont go cheap on the gas .. regardless if it costs you 200$ to fill up evry week
compromising cost/quality
I'm not really sure how I can describe how fast I was moving, but I would have considered it fairly quick. I'll definetly try out more gas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">
word .. dont go cheap on the gas .. regardless if it costs you 200$ to fill up evry week compromising cost/quality </TD></TR></TABLE>
Wow.
Another question for you guys...Would a gas cup have any effect on this as well? Right now I'm using just the standard one that came with it (can't remember the size).
Wow.
I would think 30 is a tad to high. To high can be just as bad. I usually set mine around 15cfh.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">
I would think 30 is a tad to high. To high can be just as bad. I usually set mine around 15cfh.</TD></TR></TABLE>
I remember when i went to school for tig...the instructors would always have you run around ~27cfh...Ive never had one issue running it around ~30cfh...i do run alot lower on aluminum though....
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">
Another question for you guys...Would a gas cup have any effect on this as well? Right now I'm using just the standard one that came with it (can't remember the size). </TD></TR></TABLE>
A gas lens will help....but it won't all of a sudden make the color your hoping for just appear...Can't hurt to pick one up though...everything comes with time and experience
LIsten to Jesse i seen this guy weld and he can lay some coins ,
</TD></TR></TABLE>LIsten to Jesse i seen this guy weld and he can lay some coins ,
I remember when i went to school for tig...the instructors would always have you run around ~27cfh...Ive never had one issue running it around ~30cfh...i do run alot lower on aluminum though....</TD></TR></TABLE>
The only reason I even said anything was, not to long ago I set my cfh a little higher and got horrible results.
Guest
Posts: n/a
The only reason I even said anything was, not to long ago I set my cfh a little higher and got horrible results.</TD></TR></TABLE>
what happened?
what happened?
I do know when you have it to high it can make a draft , maybe that is what happened , but any where from 30-20 you should be good , i know 20 works for me , my travle speed is not the fastest eather, you will just need to do trial and error
what happened?</TD></TR></TABLE>
The problem was almost like I had no gas turned on at all, my friend said to lower it ( it was set at about 22psi which is like 18cfh ) and when I lowered it to 15cfh the problem went away. So I did not think that big of a difference would do anything, but it indeed did.
Hrmm good to know.
What size gas cup should I be using with a 1/16" tun/filler? Also, do I need a "gas lense" or just the ceramic nozzle? ...hint hint, tell me what to buy...
Anyone know of a place that sells them online?
Thanks!
Bryson
Modified by Bryson at 2:33 PM 12/13/2005
Thanks!
Bryson
