Header Fabrication 101 (56k wait a while)
Old Dec 10, 2005 | 05:46 PM
david@didrace.com's Avatar
Default Header Fabrication 101 (56k wait a while)
I see a whole bunch of threads about 'How to backpurge?', 'How to make a jig?' blah blah blah so I'll compile all of my answers into one.
Step 1 - Buy a crapload of piping from Burn's Stainless or where ever.
Step 2 - Buy or make your own merge collectors (I'm too lazy/costwise these are cheaper for the customer/thanks Burn's for the quick turn around).
Inside of merge collector (5-1)
Notice no welding on the exterior center of the collector (read: tight fit up )
Step 3 - Form piping to exhaust port shape. I put this in a vise and clamp the pipe.
Step 4 - Here's my expensive *** jig, made by me to duplicate the stock mounting points of both passenger and driver's side stock manifolds. Each port has a tapped hole in it so I can run a argon line to each individual cylinder while I'm tacking stuff up.
Step 5 - When routing piping make sure there is clearance for things like valve covers, spark plug wires, and air-water aftercoolers for the supercharger setup you still have to bolt up above the headers.
Step 6 - Once piping is routed take the individual runners apart to weld them up.
Step 7 - My simple backpurge setup running from a seperate argon tank.
Step 8 - Polish that **** and cry because you're only halfway done if you're working on a V-10.
Modified by backpurge at 3:05 AM 12/11/2005
Old Dec 10, 2005 | 05:59 PM
RCautoworks's Avatar
Default Re: Header Fabrication 101 (backpurge)
Nice write up
Old Dec 10, 2005 | 06:17 PM
blueoval557's Avatar
Default Re: Header Fabrication 101 (90blackcrx)
Agreed. Although I have never been the one asking the questions you reffered to(I always like to see how everyone does stuff though), that write up is awesome! Great fitup with everything and as you stated, which I had been contemplating, I think I will just stick with buying the merge collectors from Burns. Too much work to get them to work right, and even then they are never as good as what Burns produces. Great write up! Thanks a bunch!
Kyle
Old Dec 10, 2005 | 06:58 PM
RMF
Guest
Posts: n/a
Default Re: Header Fabrication 101 (blueoval557)
Those look nice .I built a set that looked allot like those for Roger Mears.Back in 95 or 96 for a Dodge truck that they put a viper motor in for Pikes Peak.And yes he won his class.Those uneven number cylinder collectors are a bitch .Huh? Have you ever made a 6 or 8 into 1 collector? They are fun also.
Old Dec 10, 2005 | 07:22 PM
91TSiGuy's Avatar
Ever have problems with the runners tweeking out of shape when welding them off the flanges?
I know that you should have a really tight fitup, 4 or 8 tacks around each joint first, and weld 180* apart, 1/4 of the way passes, but can it still be possible to shrink or tweek?
Old Dec 10, 2005 | 07:44 PM
JG-Fabrications's Avatar
Default Re: (91TSiGuy)
I had this problem just a couple weeks ago on my sidewinder I was working on, ended up scrapping 2 runners completely
What I do so that this doesn't happen is weld as much as I possibly can while it is all tacked in position, then finish weld when it gets taken apart, it seems to hold up a little better for me that way.
-James
Old Dec 10, 2005 | 10:34 PM
Ekasey's Avatar
nice write up thanks for the plug guys
I always recommend when the headers are completely tacked to break the tacks on the flange, weld each tube individually, place back in ficture or whatever tweak tubes back as they will pull then weld to flnage, and retweak tubes.!
Old Dec 10, 2005 | 10:37 PM
rjay8604's Avatar
Default Re: (JG-Fab)
So that looks to be a viper header setup, V10+pushrods = viper? Anyway you wouldn't happen to be building these for SVS would you. Those guys are nuts. Good write up
Old Dec 11, 2005 | 02:29 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
good stuff!!
Old Dec 11, 2005 | 03:24 AM
Calvinator's Avatar
Default Re: Header Fabrication 101 (SYD)
nice
Old Dec 11, 2005 | 06:08 AM
Default Re: Header Fabrication 101 (xtremeazian)
It's for our shop truck but a guy who owns a business across from us has two Dodge Ram SRT-10's that he wants a set for too.
http://www.didraceengineering....0.htm
Old Dec 11, 2005 | 07:56 AM
93civic_sedan's Avatar
Looks good nice write-up...nice lookin truck too.
Old Dec 12, 2005 | 10:40 AM
aarontrini85's Avatar
wow how mutch horse power does a blown srt-10 make lol that is sic
and thanks for the great write up also
Old Dec 12, 2005 | 04:50 PM
tony1's Avatar
Default Re: Header Fabrication 101 (aarontrini85)
Looks nice, but shouldn't you be using pipe? lol
Old Dec 12, 2005 | 10:59 PM
.john.'s Avatar
Default Re: Header Fabrication 101 (tony1)
wow, i wish i could make stuff this clean
Old Dec 12, 2005 | 11:01 PM
Ekasey's Avatar
Default Re: Header Fabrication 101 (mr john)
Thats why you buy it from us
Old Dec 13, 2005 | 04:00 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">Buy a crapload of piping from Burn's Stainless or where ever.</TD></TR></TABLE>
Old Dec 13, 2005 | 07:49 AM
carbonall's Avatar
* B A N N E D *
damn that looks good!
Old Dec 14, 2005 | 07:15 AM
BlackT5's Avatar
Looks great!
How much is a Burns 5-&gt;1 collector? I'm going to need something for my Volvo project.
Old Dec 14, 2005 | 07:20 AM
Default Re: (BlackT5)
I think they were $350 or so a piece.
Old Dec 16, 2005 | 10:57 PM
714phil's Avatar
Default Re: (backpurge)
nice pics/manifold
Old Dec 17, 2005 | 11:07 AM
DamWutaDayM3's Avatar
Looks great man... But whats the secert bnehide Burns great looking collectors? You guy got a strink ray hiding some where and strink you're workers to go inside the collects and polish it or something?
Old Dec 18, 2005 | 05:16 PM
JMFabrications's Avatar
Is that 304 or 321? Very nice writeup!
Old Dec 18, 2005 | 05:27 PM
Default Re: Header Fabrication 101 (jmckeone)
304
Old Dec 18, 2005 | 05:56 PM
rpm11's Avatar
Nice writeup.
