my ls/vtec setup?
ls block w/weisco 81.5 pistons comp ht is 1.181 dome dish is 8.25 comp ratio is stated to be between 12.5 to 13.2with eagel rods with arp bolts ls crank arp main cap bolts type r oil pump gsr water pump
gsr head fully ported 3 angal valve job with omni dual vavle springs,flat bottom valves ,retainers, buddy club stage 4 cam, aebs head studs, still need adj cam gears
i got the ge ls/vtec conversion kit
i need help with getting a tb and intake mani i was looking at the aebs or the edeal brock but alot of people tell me thats only for boost but wut do u guys think would be the best mani for my setup and i was thinking 68mm tb shouldi go bigger or 68 is good and i also need lms i have an extra gsr head should i use those lms and wut thinkness head gasket should use thanks for any info
