Rate My Bead/Weld *Aluminum
Old Dec 10, 2005 | 03:04 PM
LSEGHATCH's Avatar
Default Rate My Bead/Weld *Aluminum
This was done at school with no prepwork before or after the weld. This is my first time EVER trying to weld aluminum and I think I took to it fairly quickly. I ran out of peices to weld once i was done with this plate so I couldn't practice anything else.
I'm going to pick up some more peices and learn to edge weld and then fab my first battery box and go from there. Wish me luck
Old Dec 10, 2005 | 03:18 PM
k24em2's Avatar
Default Re: Rate My Bead/Weld *Aluminum (LSEGHATCH)
Not bad.
What machine/settings/etc?
Practice Practice Practice.
Old Dec 10, 2005 | 03:28 PM
LSEGHATCH's Avatar
I am using a Miller Syncrowave, not sure what model (number) but is looks most like the 350 except that it doesn't use a pedal, gas is controlled on the torch body. Very large unit.
Old Dec 10, 2005 | 04:17 PM
ManBearPig4silly's Avatar
Very nice for your first time.
Old Dec 10, 2005 | 05:28 PM
AllmotorEH2's Avatar
looks pretty good
Old Dec 10, 2005 | 07:29 PM
92hondalude's Avatar
Default Re: (AllmotorEH2)
i like #2 that looks very nice
Old Dec 10, 2005 | 08:12 PM
LSEGHATCH's Avatar
To be totally honest, I'm better at aluminum (from what I've done) than I am at steel lol......could be a good thing once I get done with school. I was pretty good at gas welding so I think that helped alot when I started TIG.
I love to weld...like when I lifted my mask and saw that bead, I just got hit with a good feeling of accomplishment.
Old Dec 10, 2005 | 08:25 PM
VRD^don's Avatar
Old Dec 10, 2005 | 08:34 PM
Hondatec38's Avatar
Default Re: Rate My Bead/Weld *Aluminum (option_2.5)
Im also likin' that #2. Seems nice and consistant. Are you going to use filler for doing the outside corners on that battery box your gonna fab? Or do you think you'll be able to butt the ends together and fuse the panels?
Old Dec 10, 2005 | 08:37 PM
LSEGHATCH's Avatar
Filler, I like the looks of it better I like a taller (not tall as in too cold ) bead that you can see the "coin" pattern.
Old Dec 10, 2005 | 08:50 PM
B18C1CYA's Avatar
#2 looks realy good , and you got a good rythum with adding filler , man that must be a bitch with no heat control , lol
Old Dec 10, 2005 | 10:28 PM
rjay8604's Avatar
Default Re: Rate My Bead/Weld *Aluminum (B18C1CYA)
TIG is such a bitch, great job. I have trouble just laying down a bead of steel with TIG, i would say its very similar in technique to gas welding. I think its tricky trying to feed the filler and maintain consistency, great job.
Old Dec 11, 2005 | 10:41 AM
VRD^sam's Avatar
Default Re: Rate My Bead/Weld *Aluminum (rjay8604)
I could do better Tyler....j/k...looks good
Old Dec 13, 2005 | 11:18 AM
520_Motorsports's Avatar
Default Re: Rate My Bead/Weld *Aluminum (elf_vang)
looks good keep up the good work!!!!!!
Old Dec 13, 2005 | 02:23 PM
91TSiGuy's Avatar
Default Re: Rate My Bead/Weld *Aluminum (SlowAzEg)
#2 is the nicest looking out of them all, but I actually like #3 about 3/8" inch inward from where you started on the right. That looks to be a stronger, more penetrating weld than #2.
EF9_TryMe
Welding / Fabrication
Feb 5, 2012 06:08 PM
hoomzi
Nov 14, 2011 08:54 PM
Blind-Fashion
11
Apr 23, 2006 03:12 PM
.water
May 20, 2005 11:47 PM
integra-modder
22
Oct 7, 2004 10:18 AM
