Proper idle for a d16y7?
Old Dec 10, 2005 | 01:42 PM
sniperslayer's Avatar
Default Proper idle for a d16y7?
what rpm should a stock d16y7 be idling at??
mine is at 1500 right now, and that seems to high, while my buddies SI idles at around 780
Old Dec 10, 2005 | 01:54 PM
nub's Avatar
nub
Default Re: Proper idle for a d16y7? (sniperslayer)
750
Old Dec 10, 2005 | 03:03 PM
y7turbo's Avatar
Default Re: Proper idle for a d16y7? (nub)
yep mine sits at 750 and then 810 with the lights on..
Old Dec 10, 2005 | 04:00 PM
perlmeister8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniperslayer &raquo;</TD></TR><TR><TD CLASS="quote">what rpm should a stock d16y7 be idling at??
mine is at 1500 right now, and that seems to high, while my buddies SI idles at around 780</TD></TR></TABLE>
If your engine is cold, then this is the proper rpm till it warms up to operating temp. If not then check and clean your IACV.
Old Dec 10, 2005 | 04:20 PM
Default Re: Proper idle for a d16y7? (perlmeistere81)
it sits at 1500 after it's warmed up...but the thing is i think it could be my tach..
i have a DX and i just have some aftermarket tach installed, i was adjusting the idle and got it up to 2000 when it was like cranked until that little screw was almost falling out
but when i tighened it the other way until i couldnt anymore, it was just under 1500, do u think it's just my tach?
Old Dec 10, 2005 | 05:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniperslayer &raquo;</TD></TR><TR><TD CLASS="quote">it sits at 1500 after it's warmed up...but the thing is i think it could be my tach..
but when i tighened it the other way until i couldnt anymore, it was just under 1500, do u think it's just my tach?</TD></TR></TABLE>
Depends how you wired it, it sounds like an iacv problem. You should know when it idles at 750 you can barely hear it, so if it is at 1500 clean your iacv. Here's a good read on that.
https://honda-tech.com/zerothread?id=558236
Old Apr 26, 2020 | 02:39 PM
Tyler Hardy's Avatar
having an issue with my idle aswell. Popping code for P0505 which is IACV. Replaced that twice, still didnt fix my issue. I popped 2 codes for P0505 and a code for bank 1 sensor(downstream) low input. So I replaced my downstream O2 sensor hoping it would fix my issue(replaced upstream aswell) still popping a code for P0505. At this point I'm starting to believe I have a small vac leak somewhere in one of the hosses.. I also adjusted the idle screw still didnt fix my issue.
Old Apr 26, 2020 | 05:36 PM
wunfstgsr's Avatar
Loved
Community Favorite
Don't bump a 15 year old thread haha
iCollectStraws
Apr 23, 2008 11:14 AM
94c1v1cex
Jul 20, 2007 11:15 AM
kixcrx
15
Jan 9, 2007 12:52 PM
TealCivic93
May 18, 2005 06:12 PM
jerbear!
May 9, 2005 11:00 AM
