searched million times thru.. idles fine past that 3 cyl
Old Mar 15, 2002 | 10:21 AM
l's Avatar
l
Default searched million times thru.. idles fine past that 3 cyl
i have a pos ZC swap in my CRX and it has a CX exhuast manifold(have to wait to get an SIone) at idle my car is fine.. then when i give it a little throttle it starts to missfire running on 3 cylinders (the motor torques heavily)
the gas that is in it has beeen sitting there a couple years.... could this be the problem? could the manifold be causing too much back pressure?
i tried to drain the gas but then the damn screw is too tight so i cant take out a fuel line and no luck with syphening here... i dont have a pump
Old Mar 15, 2002 | 10:55 AM
4g4me's Avatar
Default Re: searched million times thru.. idles fine past that 3 cyl (IM ALL SHO)
BAd gas could definitely be the problem. I would recommend draining, even if you have to take the fuel line off the fuel rail and turn the key on.(dangerous)
dreadhead89
Dec 26, 2008 09:14 PM
confucioussae
Sep 4, 2006 10:12 PM
EF8 D-UNIT
Mar 16, 2006 04:49 PM
extreme90civic
Aug 29, 2005 06:45 PM
ransack
Oct 7, 2002 12:10 AM
