Honda CR-X (EF) problem
Old Dec 10, 2005 | 01:04 PM
daseeker's Avatar
Default Honda CR-X (EF) problem
Wuz up to everyone. My car has a serious problem-Once you let go of the steering wheel it pulls (very) hard to the right hand side. Now, when I took it to Les Schawb to fix the camber (since I had put new ground control springs), the guy working on my car said that he tried to align the car to the best he could, but said that since the "front passenger right hand side lower control arm" was bent-that it would be impossible to give the correct alignment. Now, I know that it could be a number of things, but I was wondering if anyone can confirm or deny his claim. Also if anyone can give some advise as to what could be the "possible" problem. Also I pulled out a lower control arm from a CR-X and was wondering if "simply" replaicing that part would it "fix" the problem. Thanks!
daseeker
P.S. If you look at the front right hand side passenger tire you cant just makeout that the tire is slightly "out of place" because it seems that the tire is not centered, but rather slightly pulled back (meaning pulled back towards the rear of the car). You have to look at it and measure closely in order to notice.
You can send comments/questions to my email;
djfredtek@hotmail.com
if you choose not to post here. Thanks!!!
Old Dec 10, 2005 | 01:07 PM
SD_Lurker's Avatar
HT White Ops
Default Re: Honda CR-X (EF) problem (daseeker)
fix the control arm and your problem will be solved. you must have hit something very hard in order to bend that arm. I suggest replacing it and having another alignment done and your problems should be solved. Good Luck
Old Dec 10, 2005 | 01:11 PM
ArtyG's Avatar
I doubt they're trying to rip you off. Just fix the lower control arm, and inspect the ball joint. Something similar happened to someone I know, and those were two of the things that needed to be fixed to get the proper alignment.
Old Dec 10, 2005 | 01:27 PM
spun Vtec's Avatar
Default Re: Honda CR-X (ArtyG)
Not to make you feel retarded but you did check the tire pressure to make sure that they are both the same? I know that this can make your car pull hard to one side.
Old Dec 10, 2005 | 05:09 PM
tealjdmcrx's Avatar
go to a junk yard and find a arm. Whats the most an arm can cost 15 bucks used. I have a set of sir crx arm.
Old Dec 10, 2005 | 05:14 PM
SiR Inspired ED7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tealjdmcrx &raquo;</TD></TR><TR><TD CLASS="quote">go to a junk yard and find a arm. Whats the most an arm can cost 15 bucks used. I have a set of sir crx arm.</TD></TR></TABLE>
Lanolin18
Mar 7, 2009 05:34 AM
el_gzman
Suspension & Brakes
Jun 9, 2007 10:46 AM
slow91crxdx
26
Mar 14, 2007 11:48 AM
slow91crxdx
Suspension & Brakes
Mar 2, 2007 05:31 PM
91vtecripper
Dec 13, 2002 01:09 PM
