does anyone have a ef with an obd1 b18b1?
I have a 91 si hatch with a obd1 b18b1 everything is in mounted and all wired up i have a jumper harness and running msd car is getting spark and fuel yet the spark is random when i go to start it the motor cranks then backfires could this be the timing? any help please please
i have a 91 hatch dx obd1 b18b. is it a msd box or just the coil? how did you wire up the dist? r u sure the wiring is correct?
I am running the SCI-L box i wired it into the distributor from a distributor that is was on before. therefor i belive it is correct and i also downloaded the directions off of the MSD site so i believe that it is hooked up correct. thanks for the info n e thing else thanks bro
rex_89 !!
Mar 15, 2011 12:06 AM
Eg6LazyPt
May 15, 2003 08:52 PM
