engine ICE
Old Dec 10, 2005 | 07:36 AM
01_prelude's Avatar
Default engine ICE
has anyone used the engie ice coolant thats biodegradable if so was there a tempature decrease that was noticed???
Old Dec 10, 2005 | 08:28 AM
The_Sober's Avatar
Default Re: engine ICE (01_prelude)
yes. I use it in my track bike, and I've used it in my race cars. it's awesome. But only if you live in an area that doesn't get colder than 30deg. otherwise, it'll freeze.
also, if you're going to use propylene glycol, you must completelyflush your coolant system w/ water to eliminate all of the ethylene glycol from the system. if you let them mix, it's very very bad
Old Dec 10, 2005 | 07:45 PM
01_prelude's Avatar
Default Re: engine ICE (The_Sober)
ive got a new post see if you can help me out with it. its about my car running weired.
Old Dec 10, 2005 | 08:35 PM
AzCivic1.6's Avatar
so if it'll freeze why not use water? I doubt it keeps engines cooler than regular water.
Old Dec 10, 2005 | 10:26 PM
The Captain's Avatar
Default Re: engine ICE (AzCivic1.6)
well water, in the liquid form, does have the highest specific heat, when considering naturally occuring elements, meaning it absorbs the most energy and only gains a relatively low temperature increase. this also means that it takes a lot more energy to cool that same water down. synthetically tho, there are many water substitutes designed to withstand the same amount of energy, in many cases more, and also it doesn't freeze making it clutch for situations where the temperatures go that low.
Old Dec 11, 2005 | 11:25 AM
The_Sober's Avatar
Default Re: engine ICE (98silverlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98silverlude &raquo;</TD></TR><TR><TD CLASS="quote">well water, in the liquid form, does have the highest specific heat, when considering naturally occuring elements, meaning it absorbs the most energy and only gains a relatively low temperature increase. this also means that it takes a lot more energy to cool that same water down. synthetically tho, there are many water substitutes designed to withstand the same amount of energy, in many cases more, and also it doesn't freeze making it clutch for situations where the temperatures go that low. </TD></TR></TABLE>
that's really nice what you just said, but it has no bearing on this post. nice use of chemistry textbook text, though...
Engine Ice boils at a higher temperature than water--that's what makes it better than water.
I, however, was wrong in my original post. Engine Ice will freeze below 5deg, not 30deg, like I said earlier.
my bad. but the rest of my original post was correct.
boostedcivicsir
Sep 7, 2010 10:27 AM
BLK2DOOR
Jun 13, 2010 01:29 PM
drewbie
63
Apr 23, 2010 03:10 AM
denraweb
Oct 10, 2008 03:38 PM
EngineNoO9
Honda Motorcycles
15
Dec 24, 2005 11:54 AM
