need help! I was told to come here
Old Dec 9, 2005 | 11:31 PM
doodle's Avatar
Default need help! I was told to come here
I have a 94 with an f22 vtec motor, with dc headers, dual exhaust, and v2 intake...but when im in any gear at a steady speed the car ALWAYS bogs....but I still have plenty of power..any tips will be apreciated.
Old Dec 9, 2005 | 11:46 PM
Stoich EG2's Avatar
Default Re: need help! I was told to come here (doodle)
how's your fuel filter? ever been replaced? injectors? looks to be fuel related
Old Dec 9, 2005 | 11:52 PM
doodle's Avatar
nope, never been replaced...but I will check it out....thanks
Old Dec 10, 2005 | 01:40 AM
Trumpster's Avatar
Default Re: (doodle)
I might be wrong here, but it might be the fact that you have a dual exhaust on a 2.2 liter 4cyl engine. Depending on how you have it set up, which is most likely at least 2'' piping going to both tips, you are losing backpressure and in turn you are losing power. If the car hasn't been having any other issues that you can think of that's my thought on what might be causing your issue. GL and keep us updated.
Old Dec 10, 2005 | 11:18 AM
doodle's Avatar
Default Re: (Trumpster)
no, I never had a problem with the dual exhaust I had it for about 3 or 4 years now, but im going to upgrade the fuel system. I heard AEM has good fuel components should I try them.
Old Dec 10, 2005 | 12:19 PM
P_Adams's Avatar
We sometimes saw this complaint on built up Detroit Iron; and it usually revolved around intake / carburetion selections.
True, we're now talking of intakes and throttle bodies, but the principles are the same.
You didn't mention T/B's, but a combination of both the Intake and a Larger T/B could be too large for the RPM the engine is operating in.
It would act much like putting a 900cfm Holley Double Pumper on a 2 liter Pinto motor and flooring it in forth at 30mph. You'd hear an awful lot of howling from under the hood, enough to have neighboring Dogs start singing, but you'd go absolutely nowhere!!
Try bumping it down a gear range and see if it livens up.
P
basilwatts
Honda Ruckus and Scooters
Dec 12, 2017 08:26 PM
booyah00
Mar 10, 2008 02:41 PM
layinlowon14s
Mar 27, 2007 12:29 PM
t0ekn3e
Jan 27, 2006 12:43 AM
FOrSfEd
Jun 9, 2003 09:33 AM
