removing stock stereo and cd
How do I remove the stock stereo and cd player? I have swapped cd players in my civic and other cars but I have never had to take a stock one out. Does anyone have a link to a how-to or some pics or can at least give me a run through of what I gotta do....
i have done it like 5 times first there are like 5 screws on the drivers side and 5 screws on the passenger side , then there are two screws on top of the radio (just look under and you will see it) if you are like me and have an auto transmission then just put your car in Neutral and lift the e-brake all the way up.then take off the trim around the shifter<U></U> then take off the covering. then you will see 4 screws 2 on the left and 2 on the right ,unscrew them then your done, unplug all the wires and thats all i can tell you
i just need a wiring diagram so i can install mines
so if you have a wiring diagram tell me
so I take out the REAR middle console, then take out the part around the shifter (5 screws each side) and then where are the screws on top ? Mine is 5-speed
CocoCostaRica
Jul 5, 2016 03:15 PM
fsarfino
Audio / Security / Video
24
Aug 19, 2007 08:22 AM
