Suspension & Brakes Theory, alignment, spring rates....
My alignment doesn't look right - *PICS of PRINTOUT*
Old Dec 9, 2005 | 02:45 PM
WildChild's Avatar
Default My alignment doesn't look right - *PICS of PRINTOUT*
Looks like I got almost -4 of camber. And I thought the toe was suppose to be set to .0? Looks like they set it to .16? What do you think of my alignment....
BEFORE
AFTER
Old Dec 9, 2005 | 03:02 PM
Tyson's Avatar
Default Re: My alignment doesn't look right - *PICS of PRINTOUT* (WildChild)
a little toe out in the front is fine.
the rear could have been better. they should have made that straighter. does it drive straight with a .05 thrust angle?
how slammed are you btw?
Old Dec 9, 2005 | 03:04 PM
Motorsport Masters's Avatar
What's in the "Specified" column should be the target number, and the range is the amount of error they are allowed from that number. Looks like they didn't hit the right number on the toe.
Also, they didn't touch the camber....do you have a adjustable camber kit? If you don't that's probably why camber wasn't adjusted. If you do have a camber kit, they probably didn't do the adjustment.
Old Dec 9, 2005 | 04:38 PM
WildChild's Avatar
Default Re: My alignment doesn't look right - *PICS of PRINTOUT* (Motorsport Masters)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Motorsport Masters &raquo;</TD></TR><TR><TD CLASS="quote">What's in the "Specified" column should be the target number, and the range is the amount of error they are allowed from that number. Looks like they didn't hit the right number on the toe.
Your right and that's what I was thinking. Toe is suppose to be within -0.08 - 0.08 degrees. I have .16 degrees. So this has to get changed??
Also, they didn't touch the camber....do you have a adjustable camber kit? If you don't that's probably why camber wasn't adjusted. If you do have a camber kit, they probably didn't do the adjustment.</TD></TR></TABLE>
I don't have a camber kit yet. I was thinking of raising the car up 1" to help with the camber and also get a camber aswell.
Old Dec 9, 2005 | 04:39 PM
strsi's Avatar
unless u have a camber kit, they cant adjust ur camber.
toe is off though. i prefer 0 all around. although most places wont set u exactly there unless u ask. they will set u within the specified range though, which is shown on ur printout. they missed that by a good amount, so u have all right to go back & demand them to re-do ur alignment for free.
Old Dec 10, 2005 | 08:22 AM
8krdline's Avatar
Default Re: My alignment doesn't look right - *PICS of PRINTOUT* (strsi)
almost 4 degrees of camber, damn
Old Dec 10, 2005 | 08:31 AM
ED7's Avatar
ED7
Default Re: My alignment doesn't look right - *PICS of PRINTOUT* (8krdline)
Yeah must be lowered alot man. I would raise it up an inch.
Old Dec 10, 2005 | 12:14 PM
bad-monkey's Avatar
yeah it looks ok to me cept for rear toe.
Old Dec 18, 2005 | 08:06 AM
green91's Avatar
raise it up and inch and then demand a new alignment. if you raise it up 1", your toe will be way off again.
Old Dec 19, 2005 | 06:40 PM
Budget EJ's Avatar
Default Re: (green91)
w0w, i'm suprised that the car was able to get up on the rack! But yeah, raise your car up and demand a new alignment!
bopbop93030
May 30, 2008 11:36 AM
ThePlotSickens
Suspension & Brakes
Nov 23, 2005 09:24 PM
deez nuts
Apr 14, 2005 07:43 PM
budget
Suspension & Brakes
Apr 13, 2005 02:54 PM
jdmciviceg
12
Nov 29, 2001 09:11 AM
