how can i check the year of a ls motor?
Old Dec 9, 2005 | 11:41 AM
Project_EK's Avatar
Default how can i check the year of a ls motor?
what up,
i'm going to look at a LS motor tonight..the guy says its a 97, but how can i check???
thanks
Old Dec 9, 2005 | 11:44 AM
Siberian Husky's Avatar
Default Re: how can i check the year of a ls motor? (EKhatch219)
get the vin/serial on both the head and the block (making sure they match, as sometimes people replace heads/blocks or mix n match)...im not sure where you can run this number..but this is what you should do..im sure someone else on here willlet you know where to run the # to get the 411 on the engine
Old Dec 9, 2005 | 11:45 AM
Luserkid's Avatar
Has the head or the block been taken appart? If there still together then the stamp is on the head above the exhaust manifold between 3 and 4.
Old Dec 9, 2005 | 12:16 PM
A.E Motoring's Avatar
Default Re: how can i check the year of a ls motor? (Luserkid)
just look on the front of the head
Old Dec 9, 2005 | 12:48 PM
Project_EK's Avatar
okay i'll check that..thanks
Old Dec 9, 2005 | 01:16 PM
Project_EK's Avatar
also does anyone know the tranny code for a 94+ ls tranny?
Old Dec 9, 2005 | 09:02 PM
transpar_nt's Avatar
Default Re: (EKhatch219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch219 &raquo;</TD></TR><TR><TD CLASS="quote">also does anyone know the tranny code for a 94+ ls tranny?</TD></TR></TABLE>
It'll either be y80 or s80 depending on the year, but I believe ALL usdm and jdm b18 trannys are stamped likewise regardless of internals.
egaustinmellon
Apr 19, 2012 10:43 PM
skiracer8148
Mar 31, 2007 06:47 PM
94whitegsi
Dec 13, 2006 09:05 PM
Turbo Squid
Nov 2, 2005 06:58 PM
TeginRAGE
Jun 27, 2002 06:53 PM
