Wiring clutch pedal from auto to manual swap
22812 018 1 SWITCH ASSY., CLUTCH (12MM) (INHIBITER) NO COLOR 40.55 30.39 Qty:
22815 019 1 SWITCH ASSY., CLUTCH (10MM) (TEC) NO COLOR 25.38 19.05
are they or is one of them the correct part number..
hondaautomotiveparts.com
you could use a starter interrupt relay. There is a starter interrrupt already in your car, so that it won't start when in drive or reverse, etc. the wiring would be in your center console, plugged into the auto shifter mechanism. The starter wire should be black with a white stripe. Using a standard SPDT relay, wire in pin 30 to one of the wires and pin 87a to the other. It doesn't matter which one is which. Pin 86 goes to a true ignition power source(has to stay powered when key is in start position). tape up and protect pin 87 from making any contact. Pin 85 will go to one of the pins on your 2 pin clutch switch. The other pin from the clutch switch will go to ground. Now the car will not start unless the ignition is on and the clutch pedal is pushed in. Good luck!
JokerX-1.6T
Jun 8, 2007 05:08 PM
