-- OD1 B16A STARTER NOT WORKING (CRX Si) --
To All,
I have a 1990 CRX Si w/ B16a in it. The engine is a first generation motor OD1. The starter has gone bad and is not working any more. I need to get this replaced. What are my options in regards to a starter. Should I be looking at the startes for the 92 - 93 GSR's or are there any other models that I can match it up with? Thank you for your time!
as far as starters go any b series should work just fine since its only two wires your main and the little black one that plugs in.. on the side... obd doesnt matter..
almost any b series starter(manual) will work,integra 90-93 and 94 up, not sure about prelude b's though, although the integra starters look different(the newer ones are smaller) they will both work
bobbyhill
Nov 4, 2007 02:10 PM
fulldragcrx
Dec 10, 2003 06:39 PM
