gsr brakes on a crx
Old Dec 9, 2005 | 09:32 AM
civicslayrx's Avatar
Default gsr brakes on a crx
Yes i searched. I could have sworn i saw a link on here about swapping gsr brakes onto a crx. I would like to do the swap. Does anybody know the page that has the gsr brake swap guide on it?
Old Dec 9, 2005 | 09:40 AM
Autoworks's Avatar
Default Re: gsr brakes on a crx (civicslayrx)
Its in theFAQs at the top of the forum
If you are doing the front, all you do is replace the knuckles, rotors and calipers off of a DA
Old Dec 9, 2005 | 10:39 AM
I looked through the faq. I found a link, but it doesn't work. Hey while I'm here, IF i do a b series, could i use the gsr axels, or would they not work?
Old Dec 9, 2005 | 04:59 PM
CRXb18Turbo's Avatar
Default Re: (civicslayrx)
i think you have to use DA one.
Because of the DA intermed. shaft.
Old Dec 9, 2005 | 07:20 PM
what year teg do i pull the brakes from?
Old Dec 9, 2005 | 10:02 PM
B18aHatch's Avatar
DA - 90-93 integra
pull the front knucles with brakes from any 90-91 ... i prefer to get non-abs but i dont know if you can use the abs hubs or not....
Old Dec 10, 2005 | 07:43 AM
cr-x-91's Avatar
or u could use the 91 civic ex sedan. same thing and i believe the geomotry is the same as the ef crx/hatch. i did this on my crx.same size everything.
littlebluecrx
Feb 13, 2010 04:54 PM
1_slow_crx
Dec 22, 2006 07:45 PM
deucedeuceEK
Jan 12, 2006 01:13 PM
ooairewreckoo
Dec 13, 2005 12:14 PM
jdm4show
May 20, 2004 09:46 PM
