1st Gen Integra bolt pattern? 4x100?
Is the 1st gen integra bolt pattern a 4x100 just like the 88-91 crx? Will the crx hubs on their 4x100 wheels fit on these cars?
I'm asking because I know miata wheel bores are smaller than the crx hub, so you have to do some nice dremel work to make them fit.
for others searching later:
what is the 2nd gen, 3rd gen, and 4th gen integra bolt patterns?
The bolt pattern for all 1st, 2nd, and 3rd gen Integras is 4x100 (except for the Type R). There is no 4th gen integra, unless you consider the RSX.
if you go to http://www.g1teg.org (86-89 integras) or http://www.redpepperracing.com (86-89 civics) they should have some info on hub swaps. I am betting the front is slightly different because the suspension for the 86-89 Integra used a torsion bar system, but the rear suspensions on those 2 cars are pretty similar (for example, you can use 88-91 civic rear shocks on the 86-89 integra rear).
Awesome. Well hopefully my 4x100 steelies with nokian hakkappallitta (spelling, lmao) wheels fit on this 88 integra sedan i'm buying for a winter beater.
My Jetta TDI does not like snow at all. Torque monster spinns like crazy, and going up snowy roads from a parked stop, it just spins and that sucks.
Don't get a TDI for anything except for non-snowy highway driving.
nicknack25
Jul 26, 2014 05:24 PM
el_Presidente
May 15, 2003 09:59 PM
