switching wire harness
Old Dec 9, 2005 | 08:06 AM
b_serious's Avatar
Default switching wire harness
hey guys just had a quick question..
im running a b18b in my 98 coupe.. with stock wire harness and stock ecu
how hard would it be to switch the wireharness and ecu to an LS harness and computer
Old Dec 9, 2005 | 08:51 AM
d16vtecx's Avatar
Default Re: switching wire harness (b_serious)
no need to change your harness but it takles about an hour
make sure you label the sensors
just switch your ecu takes 5 min
Old Dec 9, 2005 | 08:57 AM
95gainfla's Avatar
why would you want an LS wiring harness in the first place?
Old Dec 9, 2005 | 09:28 AM
b_serious's Avatar
Default Re: (95gainfla)
i just want everything to run normal with all sensors connected.. i have alot of unplugged connectors that have nothing to plug into, for example its missing the intake manifold temp sensor and i think the ecu is fried anyways running in warm up mode the whole time idling at 1.5k and getting bad gas milage
Old Dec 9, 2005 | 11:45 AM
Rywire's Avatar
Default Re: (b_serious)
use the cars harness, dont try anything else
turboblack2door
Jan 23, 2012 03:34 AM
Mikey3000
Jun 24, 2008 04:59 PM
QuangAlang
Nov 30, 2006 11:25 PM
