anybody have a dyno of a b16a2 when vtec isnt engaged at all?
Old Dec 9, 2005 | 06:42 AM
RACEPAK's Avatar
Default anybody have a dyno of a b16a2 when vtec isnt engaged at all?
hello everybody...
thx
Old Dec 9, 2005 | 08:39 AM
vancoland's Avatar
why?...its a vtec engine...and if its not engaging...why would you run it on a dyno? Theres obviously something wrong there
Old Dec 9, 2005 | 09:28 AM
Hybrid96EK's Avatar
Default Re: anybody have a dyno of a b16a2 when vtec isnt engaged at all? (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">hello everybody...
thx
Yeah, it put down 69whp and 45ftlbs of torque.
Old Dec 9, 2005 | 09:39 AM
Dueceification's Avatar
Default Re: anybody have a dyno of a b16a2 when vtec isnt engaged at all? (Hybrid93Eg)
damb mine put down 101whp & 56lbs/tq LOL I dont think anyone has done that. But for sh*ts and giggles it would be funny.
Old Dec 9, 2005 | 09:57 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: anybody have a dyno of a b16a2 when vtec isnt engaged at all? (93b16hatch)
Here's a stock b16
Old Dec 9, 2005 | 10:10 AM
GetawayInMoscow's Avatar
Default Re: anybody have a dyno of a b16a2 when vtec isnt engaged at all? (litterbox)
Wow really only 97.7 ft lbs?
Good thing I have a turbo sitting next to me waiting to go in mine
Old Dec 9, 2005 | 10:32 AM
Hybrid96EK's Avatar
Default Re: anybody have a dyno of a b16a2 when vtec isnt engaged at all? (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">Wow really only 97.7 ft lbs?
Good thing I have a turbo sitting next to me waiting to go in mine </TD></TR></TABLE>
Even with that turbo, the B16 suffers from a major setback... lack of stroke. If you want torque, its not the way to go. sorry guys.
Old Dec 9, 2005 | 11:14 AM
RACEPAK's Avatar
THANKS GUYS
Old Dec 9, 2005 | 11:54 AM
boostedcivicsir's Avatar
Mr. Badwrench
i think mine put down 180 at 15 psi with no vtec i cant remember. it was a long time ago.
Old Dec 9, 2005 | 12:12 PM
postman's Avatar
to bad the hatch with the b16 on the dyno was running lean as ****
Old Dec 9, 2005 | 12:16 PM
CRXified's Avatar
Default Re: anybody have a dyno of a b16a2 when vtec isnt engaged at all? (postman)
it that dyno with no vtec? its a pretty smooth cross over it it was running vtec
Old Dec 9, 2005 | 12:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Even with that turbo, the B16 suffers from a major setback... lack of stroke. If you want torque, its not the way to go. sorry guys.</TD></TR></TABLE>
Yeah but it will double 97.7 ft lbs no problem, which is a big help.
Old Dec 9, 2005 | 01:58 PM
Sketch_hs's Avatar
my b16 made 158whp 111tq
with i/h/e & test pipe
Old Dec 9, 2005 | 10:35 PM
postman's Avatar
Default Re: anybody have a dyno of a b16a2 when vtec isnt engaged at all? (CRXified)
the air/fuel graph shold be reading around 18. not 15 down to 12especiaalyhigher in rpms. 15 is good at idle soon as start running it hard. like on dyno you car gets richer. not leaner.
Old Dec 9, 2005 | 11:15 PM
Sketch_hs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">the air/fuel graph shold be reading around 18. not 15 down to 12especiaalyhigher in rpms. 15 is good at idle soon as start running it hard. like on dyno you car gets richer. not leaner.</TD></TR></TABLE>
ban
His AFR is good. Higher numbers are leaner. AIR/FUEL
Old Dec 10, 2005 | 12:06 AM
Hybrid96EK's Avatar
18:1 = pretty damn lean... also, stock Hondas typically run a little rich on the idle, not lean.. 15:1 might be "ok", but you can certainly run a good amount richer with no problems also..
Old Dec 10, 2005 | 12:40 PM
postman's Avatar
yeah yeah my bad i as thinking *** backwards that day. 1 to many old E's.
Old Dec 10, 2005 | 12:51 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">Even with that turbo, the B16 suffers from a major setback... lack of stroke. If you want torque, its not the way to go. sorry guys.</TD></TR></TABLE>
if you have a b16 and you want more piston speed, then get a 4.785 final
Old Dec 10, 2005 | 01:32 PM
Hybrid96EK's Avatar
Default Re: anybody have a dyno of a b16a2 when vtec isnt engaged at all? (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">
if you have a b16 and you want more piston speed, then get a 4.785 final</TD></TR></TABLE>
Umm.. How is this going to increase piston speed? News flash, IT WON'T.
Old Dec 10, 2005 | 02:01 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">Umm.. How is this going to increase piston speed? News flash, IT WON'T.</TD></TR></TABLE>
more engine cycles = more piston movement.
also, what's better than inhaling air through the same size intake port?
inhaling air more times per minute.
Old Dec 10, 2005 | 02:28 PM
Hybrid96EK's Avatar
inhaling air more times per minute.</TD></TR></TABLE>
Its not going to "raise piston speeds" like you said. Piston speeds will be dictated by rod/stroke ratio. While it might raise revolutions per minute... Its not going to change piston speeds as you have stated. I guess if you consider piston speeds the same as RPMS...
Old Dec 10, 2005 | 03:03 PM
SkankyEJ7's Avatar
Old Dec 10, 2005 | 03:57 PM
SkRiBLaH's Avatar
Default Re: anybody have a dyno of a b16a2 when vtec isnt engaged at all? (98ekhx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ekhx &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
agree
turbodano
Feb 5, 2008 10:37 AM
Mantis
Honda S2000
45
May 4, 2006 06:25 PM
liquids0ap
Apr 26, 2003 07:21 PM
KS-R
Dec 21, 2001 07:30 PM
