cheap delsol si sohc vtec 5sp nj
car is located in nj
i have a 93 delsol si id like to sell outright for $ 1700
- pics by sat
- head and block milled to true also to bump compression to 10.56 to 1 ..
- new oem rings and bearings 22k ago
- gsr springs and struts 60k miles on them
- 190 across but #3 has 185
- Raxel axels good to 300 hp
- LS throttle body
- 4-2-1 DC sports ceramic header
- new rings and bearings 20k ago
- 05 civic special edition wheels with 9k miles on them
- brembo rotors and hawk pads
- unorthodox underdrive crank pulley
- aem underdrive alt pulley
- z6 trans w/ 85k also included 2 extra trannys and one extra set of axles
- new timingbelt, water pump, headgasket
- new "autozone special" clutch
- es motor mounts and suspension bushings
- other than that stock
- milano red only needs driver front fender is wrinkled needs paint
- i have alot of spare parts id give with the car like i have an extra tranny an
extra set of winter rims, an spare head, extra set of calipers, and a larger front
sway bar.. and rear sway bar from a 01 gsr
Modified by gotboostedvr6 at 11:28 PM 12/11/2005
Modified by gotboostedvr6 at 12:06 AM 12/25/2005
- pics by sat
- LS throttle body
chassis has 175 motor has 20k mile fresh rebuild and im including 2 extra trans
trans in car is good but i dont need the sohc stuff anymore
hood has light dings on it from a hail storm, the driver fender needs paint,
and the drivers door has damage on it but also only needs paint and ill get pics of it all today after 2
