Extendin the o2 sensor?
Old Dec 9, 2005 | 12:26 AM
JFG Kevin's Avatar
Default Extendin the o2 sensor?
What can i use to extend the o2 sensor wire?
Old Dec 9, 2005 | 05:09 AM
snatch's Avatar
Default Re: Extendin the o2 sensor? (aznstyler119)
More wire.
Seriously, just cut the O2 sensor wire, then attach a new wire to it of the desired length. Only do 1 wire at a time though so you don't get mixed up with which wire goes to which when they're all cut. Would be best to solder your connections also. I've been running it for ~2 years with no issues.
Old Dec 9, 2005 | 12:43 PM
gsrious's Avatar
Default Re: Extendin the o2 sensor? (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">More wire.
Seriously, just cut the O2 sensor wire, then attach a new wire to it of the desired length. Only do 1 wire at a time though so you don't get mixed up with which wire goes to which when they're all cut. Would be best to solder your connections also. I've been running it for ~2 years with no issues. </TD></TR></TABLE>what gauge wire did you use?
Old Dec 9, 2005 | 12:45 PM
snatch's Avatar
Default Re: Extendin the o2 sensor? (gsrious)
Comparable to what was used on the existing sensor. I'm not sure off the top of my head but ~16-18 AWG.
Old Dec 9, 2005 | 09:22 PM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">More wire. </TD></TR></TABLE>
lol
crapanese
Nov 8, 2006 09:57 AM
SimbaDogg
18
Jan 29, 2005 10:42 AM
Frankinfreak300
Sep 27, 2003 08:43 AM
fastcrxs1
May 23, 2002 04:11 PM
