Rearview mirror adjustment on 5th Gen.
Old Dec 8, 2005 | 09:49 PM
skimeast1982's Avatar
Default Rearview mirror adjustment on 5th Gen.
My rearview mirror has suddenly became very loose . Is there a way to tighten it back up? If so how do I take the cover apart to get at the inside? the mirror itself is not loose...just the "arm"
Old Dec 9, 2005 | 09:04 AM
BB6racer's Avatar
pry the dome light off with a small flathead screwdriver, and carefully remove the bulbs inside. you should be able to see some screws and bolts in there. just start removing bolts and screws, and remember where they go. eventually you will be able to get at the bolts for the mirror and then just tighten them up. i have never actually taken that much off, but i did take the bulbs out and remove the plastic cover thing. oh, and this is for a 5th gen.
Old Dec 9, 2005 | 09:52 AM
iLude's Avatar
Default Re: (BB6racer)
Good info. Any idea if this is similar to a forth gen? Mine's becoming a little loose...
Old Dec 9, 2005 | 10:42 AM
shutta's Avatar
if it's the whoel assembly on the winshield, take a phillips screwdriver to the screw in the underside of the elbow going to the winshield. if it already fell off, loosen it, slide it into teh clip that's on the winshield, and tighten it while you hold it all teh way in the clip.
if you can't understand what i said, i'm sorry, it's not my fault you don't know how to tighten it.
Old Dec 9, 2005 | 10:58 AM
iLude's Avatar
Default Re: (shutta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta &raquo;</TD></TR><TR><TD CLASS="quote">if you can't understand what i said, i'm sorry, it's not my fault you don't know how to tighten it.</TD></TR></TABLE>
What's with the attitude? I never even looked at it so I have no idea how easy it might be. You don't have to be a dick about it...
Old Dec 9, 2005 | 05:07 PM
shutta's Avatar
sorry.
ı Justin ı
May 12, 2010 06:51 AM
fyre
Nov 15, 2006 07:04 AM
RusBear
Dec 16, 2005 01:34 AM
pumafeet10
Oct 28, 2004 06:50 PM
