dash
Old Dec 8, 2005 | 09:27 PM
civicslayrx's Avatar
Default dash
I own 2 crx's, a red 91 hf, and a black 89 hf. I'm in the process of fixing up my black crx (the red one is totaled). Any ways the dash in my black crx id cracked, and i was wondering if i could install the dash from the 91 into the 89? The 89 has a squar cluster, and the 91 is round, so im not sure if it would bolt up, thoughts comments? feel free.
Old Dec 8, 2005 | 10:43 PM
crxnj's Avatar
Default Re: dash (civicslayrx)
Yeah you can do it..There's 1 bolt that doesnt work,and the plug for the hazard lights is different..And you can put the 90-91 cluster shroud on the 88-89 cluster so it will just go in..Or you can put the 90-91 cluster in but the wiring is a little different..
Old Dec 9, 2005 | 06:21 AM
I noticed the hazards were different, I'm going to move my original dimmer **** and defroster boutton under the dash (hard to explain). I'm going to pop out the hazard button, and dimmer **** on the new cluster shroud. And replace with a thin peice of sheet metal for my toggles.
BSeriesRescueteam
May 7, 2009 10:29 AM
JokerTypeR
Feb 3, 2008 07:35 AM
JokerTypeR
Dec 27, 2007 07:41 AM
julioboostamante
Dec 7, 2007 04:57 PM
