swappable parts from a DA(90-93)
My friend recently acquired a wrecked DA(which suffers from some front end damage front what I have been told). To what degree I am not sure, other than the fact that I know its not driveable and the radiator isn't any good anymore either. I know most of the obvious parts that will swap over to my car, for instance brakes, seats, master cylinder, various interior pieces, etc.
I was curious as to if there were any other parts that are swappable from the DA integra. He told me that if I pull the motor out and leave him the block(cause the B18B block he currently has is jacked up) as well as the rear discs I could have anything else I wanted (as he doesn't like to do work, in any way shape or form). Obviously I concurred.
There will be a lot of parts that will be put up for sale. so make sure you reply and tell me what things are worth keeping. I appreciate the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">get the front sway bar
cheap OEM 22mm bar
that bolts on the crx?
cheap OEM 22mm bar
</TD></TR></TABLE>that bolts on the crx?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">if you took the time to read he said the radiator is toast</TD></TR></TABLE>
Oh,,My bad
Oh,,My bad
yeah, too bad he's using those too haha, that would be real nice to have. I forgot to mention that earlier. Either way, it'll be nice to get some stuff off there whenever he starts stripping it down. he's being a jiveturkey about it at the moment, so I might just forget the whole thing.
cheap OEM 22mm bar
its 23mm and hollow, and yes it does fit on the EF's.
cheap OEM 22mm bar
</TD></TR></TABLE>its 23mm and hollow, and yes it does fit on the EF's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">nothing is needed. just get the 23mm bushings with the bar. the endlinks are the same. the bracket that captures the bushing is different on the DA, so use the EF's.</TD></TR></TABLE>
What would this do to the balance of the car in regards to road racing/HPDE?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">Take that radiator..It has metal on top instead of the bullshit plastic on ours..And it's a direct replacement..</TD></TR></TABLE>
Are you 100%sure the DA and CRX radiators are the same??
i have a da radiator in mine right now, all the stock mounts fit it fine and it holds 3 times as much coolant, the stock crx fan even lines up, well sorta i had to bend one mounting hole on the fan about 1/4 inch no big deal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">i have a da radiator in mine right now, all the stock mounts fit it fine and it holds 3 times as much coolant, the stock crx fan even lines up, well sorta i had to bend one mounting hole on the fan about 1/4 inch no big deal
Good, my brothers DA hs been sitting in my driveway for a year now with a blown headgasket and a BRAND NEW stright from Honda radiator...I forsee it getting jacked in the near future.
</TD></TR></TABLE>Good, my brothers DA hs been sitting in my driveway for a year now with a blown headgasket and a BRAND NEW stright from Honda radiator...I forsee it getting jacked in the near future.
