Main relay problems
Ok my main relay in my 85 crx si started clicking like crazy and my car would not turn over> So i ordered a new relay now it does the same thing. The relay is brand new what else could be the problem. help i need to move my car i am moving in 2 days!
Check all of your fuses with a multimeter, don't just eye them up. A couple like to go bad when the relay goes, and if you eye them up they look fine and you end up running in circles.
make sure you have all grounds in the engine bay connected. I just swapped a zc motor in my car and had the same problem till I connected the last ground at the back of the engine bay. I think its the thermostat housing ground or something.
sd619jef9
17
Feb 5, 2017 08:20 AM
MonkeyPuzzle
26
May 25, 2009 09:15 AM
rocaveli
33
Jul 13, 2005 03:16 PM
