shift linkage?
Old Dec 8, 2005 | 08:37 PM
ekb16's Avatar
Default shift linkage?
i bought a complete changeover b18c from hmotorsonline and i am using the stock gsr shift linkage. i got the hasport motor mounts and the SI rear "L" bracket.. everything bolts up good. my problem is that it pops out of gear and i dont think its the dents. it pops out of 3rd and 5th but not 4th or Rev. i have a feeling that the linkage is too short and not going into 3rd and 5th all the way.. would i need aftermarket linkage or should the stock gsr fit?
Old Dec 8, 2005 | 09:41 PM
underb00steg6's Avatar
Default Re: shift linkage? (ekb16)
sounds like it could be the tranny ...not the shift linkage
Old Dec 8, 2005 | 09:49 PM
pdiggitydogg's Avatar
^yep
Old Dec 8, 2005 | 09:53 PM
egryda's Avatar
Default Re: (pdiggitydogg)
all B series linkages are the same.
Old Dec 9, 2005 | 11:52 PM
transpar_nt's Avatar
Default Re: (egryda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egryda &raquo;</TD></TR><TR><TD CLASS="quote">all B series linkages are the same.</TD></TR></TABLE>
I know the one from the DAs is an inch shorter FOR SURE.
Old Dec 10, 2005 | 12:04 AM
littleredcivic's Avatar
so you have the stock b18c gsr shift linkage right? its more likely the transmission has a bent shift fork...
CHANCELLOR12
Jan 23, 2017 06:46 PM
SupraRXZ
Feb 9, 2006 04:35 PM
Egone
May 25, 2005 12:35 PM
G U E C O
Aug 18, 2003 10:36 PM
