crx with hydraulic tranny..help
Old Dec 8, 2005 | 07:13 PM
g24jr's Avatar
Default crx with hydraulic tranny..help
if the tranny already has a slave cylinder and lines on it cant you just hook something to the hydro line instead of putting on the hydro to cable conversion?
Old Dec 8, 2005 | 08:18 PM
dr_latino999's Avatar
Default Re: crx with hydraulic tranny..help (g24jr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g24jr &raquo;</TD></TR><TR><TD CLASS="quote">if the tranny already has a slave cylinder and lines on it cant you just hook something to the hydro line instead of putting on the hydro to cable conversion?</TD></TR></TABLE> Do you see a Clutch Master cylinder anywhere in your engine bay? Mind that a clutch fluid resevoir? If you do, hook it right up, but you don't, and it's not possible (firewall clearance) to run an OEM pedal set and use a Hydro set up in our chassis without cutting bits out of said firewall.
th4crush4
Dec 2, 2016 01:03 PM
diamondstarsforever
35
Oct 11, 2010 01:15 AM
Sleepy_Red_hatch
29
Oct 7, 2005 03:03 AM
Dancing is Forbidden
Dec 30, 2003 10:58 PM
tgreaves
Nov 17, 2003 12:30 PM
