B16a bogging BAD in vtec! Any ideas?
Old Dec 8, 2005 | 07:10 PM
Rywire's Avatar
Default B16a bogging BAD in vtec! Any ideas?
This guy brings me his car... its a b16a obd1 running a chipped po6 ecu. We swapped my old gsr dizzy on... its not the dizzy. He was getting a random code for the TPS, so I had another and put it on. No dice...
It will rev all the way to 8, but only if you rev very slowly. If you mash it it just bogs like no other.
There is a dent in the oil pan, and the fuel filter needs to prolly be replaced... man, other than that I just dont know!!
Anyone have ideas?
Old Dec 8, 2005 | 07:13 PM
crexer's Avatar
Default Re: B16a bogging BAD in vtec! Any ideas? (droppedcrxsi)
checked the timing? Maybe get a timing light to be 110% sure
Old Dec 8, 2005 | 07:21 PM
Rywire's Avatar
Default Re: B16a bogging BAD in vtec! Any ideas? (crexer)
Thanks, keep em coming!
It idles like a dream, runs great, its just if you hit the throttle if freaks out!
Old Dec 8, 2005 | 07:23 PM
fourthgenhatchB17's Avatar
Change the fuel filter then. Maybe its not getting enough fuel psi?? Check the plugs?
Old Dec 8, 2005 | 07:32 PM
Rywire's Avatar
Default Re: B16a bogging BAD in vtec! Any ideas? (fourthgenhatchB17)
Ya, fuel filter is going to be done, and he said they were new plugs, but they could be bosh or something, so who knows. Well check them too....
Old Dec 8, 2005 | 07:58 PM
Chief Wenceslaw's Avatar
Check the o2 sensor. I had mine disconnected for a while, and it bogged real bad after where VTEC was supposed to be engaged.
Old Dec 8, 2005 | 08:22 PM
Old_Honda's Avatar
Default Re: B16a bogging BAD in vtec! Any ideas? (Chief Wenceslaw)
Apart from the aforementioned timing, fuel filter, plugs, and o2 sensor, ask him what brand of gas he uses. Could be some shitty arco gumming up the works.
Old Dec 8, 2005 | 08:24 PM
crxnj's Avatar
I think its a fuel related problem..Maybe in vtec its running to rich causing it to bog,,What is the ecu chipped with??
Old Dec 8, 2005 | 09:12 PM
Rywire's Avatar
Default Re: B16a bogging BAD in vtec! Any ideas? (Mr.speaker)
I put another ecu in there.... Peters p28, and it was the same
Old Dec 8, 2005 | 10:00 PM
.john.'s Avatar
i had a car with a similar problem and turned out to be a clogged cat, i know it doesnt explain it being at the changeover but it was the same on this car. mine was a 95 gsr integra, so basically the same. when the changeover happens the motor is trying to get more exhaust through the cat but it just wasnt having it.
Old Dec 9, 2005 | 12:54 AM
gnar kill's Avatar
Default Re: B16a bogging BAD in vtec! Any ideas? (mr john)
are you sure vtec is actuating?......there could be something clogged in the vtec seleniod assembly not allowing vtec to work right....jut an idea......
Old Dec 9, 2005 | 01:13 AM
PURPLETERROR aka BIGMATT's Avatar
mapsensor, or mechanical cam timing is off
Old Dec 9, 2005 | 01:27 AM
Jeff's Avatar
Banned
Check the sensors and also the throttle body, My throttle body was dirty like no other and it did that, The butterfly was sticking so it would run like ***.
Also check the fuel filter.
Old Dec 9, 2005 | 04:39 AM
Autoworks's Avatar
Default Re: (Jeff)
Clogged fuel pump, or clogged fuel filter...probably the pump. That's what was wrong with mine, the walboro got clogged from rust or what not in my old tank. On the dyno when VTEC would come in fuel pressure would drop like a dead bird, the car would bog...it just sucked Replaced the tank, cleaned out the pump filter
Old Dec 9, 2005 | 11:37 AM
Rywire's Avatar
Default Re: (Autoworks)
Thanks for all the suggestions... The throttle body is for sure clean, I cleaned it when I took it off.
A little more info... I guess this just started happening one day all the sudden. Thanks again for all the suggestions~!
Old Dec 9, 2005 | 07:01 PM
.john.'s Avatar
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all the suggestions... The throttle body is for sure clean, I cleaned it when I took it off.
A little more info... I guess this just started happening one day all the sudden. Thanks again for all the suggestions~!</TD></TR></TABLE>
all of a sudden could definately be the cat, as maybe a piece of the honeycomb broke off and is now blocking the exit.
Old Dec 9, 2005 | 10:36 PM
Rywire's Avatar
Default Re: (mr john)
ill have him run it open header and check it out! Thanks
Old Dec 10, 2005 | 04:57 AM
Autoworks's Avatar
Mine reacted all the sudden. The fuel pump was gradually clogging, but never bogged like hell till it hit the dyno that day...that's why it was so weird to me.
Old Dec 10, 2005 | 06:52 AM
Fred n J_v2.0's Avatar
i would think either the 02 is messed up or a clogged cat
Old Dec 10, 2005 | 08:28 AM
ED7's Avatar
ED7
Default Re: (Fred n J's_1.8's)
Thats not an o2 sensor problem. I would look into an ignition misfire. Check the coil, cap and rotor, spark plugs and wires.
Old Dec 10, 2005 | 08:41 AM
Boosted Chemist's Avatar
Default Re: (ED7)
dented oil pan might cause low oil pressure. ARe you sure vtec is engaging?
j_mee_5
Aug 17, 2010 09:47 AM
toolbox21
Apr 1, 2009 02:35 PM
sohctodohc
30
May 23, 2007 09:44 AM
dragaholic
Feb 23, 2007 11:05 PM
j87w
28
Jan 11, 2006 03:45 PM
