Springs Will They Work?
I just purshased some springs they are for a CRX 1989 and I wanna know will they work on A 89 SI. I think they will. Also how has a nother question how hard is it to install strut and springs......
If they are OEM, the only difference is spring rate. Slightly higher for the Si, maybe a little shorter too. But as far as fitment, that is a non-issue, its all the same.
It's not too hard with basic tools, just time consuming. If you plan on doing this work yourself, you should have a Helms service manual and a spring compress (which you can rent/borrow from local autoparts stores).
Smackin
Dec 7, 2018 11:59 AM
GTA
May 22, 2006 07:53 AM
guttedsilvercrx
Nov 4, 2003 06:01 PM
J.R.
Aug 24, 2002 05:20 PM
