LS Rods w/itr pistons
Old Dec 8, 2005 | 04:46 PM
john_racer's Avatar
Default LS Rods w/itr pistons
I am building a all-motor ls/vtec and was wanting to know if the ls rods will work all right with itr standard size pistons. I looked up the comp. ratio it is supposed to be 11:5 which seems good for 92 premium pump gas and for a daily drivin motor
Old Dec 8, 2005 | 04:48 PM
juicy629's Avatar
Default Re: LS Rods w/itr pistons (john_racer)
type "itr pistons on ls rods" in the search portion of the website.. make sure you select archived.. youll have tons of results... i think 5 pages.. about 12 threads will answer your questions.. the rest are forsale adds.. gl
jesse
Old Dec 8, 2005 | 04:58 PM
duh naNG's Avatar
Default Re: LS Rods w/itr pistons (juicy629)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicy629 &raquo;</TD></TR><TR><TD CLASS="quote">type "itr pistons on ls rods" in the search portion of the website.. make sure you select archived.. youll have tons of results... i think 5 pages.. about 12 threads will answer your questions.. the rest are forsale adds.. gl
jesse</TD></TR></TABLE> Just to chime in. I'm pretty sure you have to have 3 letters or more in each word for it to search.
Old Dec 8, 2005 | 08:27 PM
gsrious's Avatar
remember that when you use ls rods... you have to use an ls crank.
Old Dec 8, 2005 | 08:38 PM
allinone07860's Avatar
Default Re: (gsrious)
if u use ls rods with itr pistons i think u have to shave 1mm off each of the rod for the piston to fit
Old Dec 8, 2005 | 08:41 PM
Hoppa's Avatar
wat is your oversized piston? .25 oversized? i have the jdm .40 oversized pistons on my ls rods and ls crank, balanced and edged, and its a great build and is strong and was built to last. itll be fine, all i gotta say is make sure who puts it together knows what there doing cause thats wats matters is who puts your motor together.
Old Dec 8, 2005 | 08:49 PM
gsrious's Avatar
Default Re: (allinone07860)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allinone07860 &raquo;</TD></TR><TR><TD CLASS="quote">if u use ls rods with itr pistons i think u have to shave 1mm off each of the rod for the piston to fit</TD></TR></TABLE>you thinking you know is not good enough for honda-tech. you only have to shave the pistons if they are b16 rods.
Old Dec 9, 2005 | 08:46 AM
juicy629's Avatar
nope!.. to use ls crank you must us ls rods.. and to use ls rods you must shave 1 mm on each side of the wrist pin side..
Old Dec 9, 2005 | 11:49 AM
DA1's Avatar
DA1
Default Re: (juicy629)
Exactly
Old Dec 9, 2005 | 12:33 PM
gsrious's Avatar
ahh expletive it... i was thinking about pr3 pistons.
ok, you guys are right... im sorry.
Old Dec 12, 2005 | 10:14 PM
lol i only say i think because i was trying to give a quick answer and i dont know off the top of my head exactly how much it was but im glad u got taught every car is different
Old Dec 13, 2005 | 12:00 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">you thinking you know is not good enough for honda-tech. you only have to shave the pistons if they are b16 rods.</TD></TR></TABLE>
ls rods and b16a rods have the same small end size, both b16a, b17 and ls rods have to be shaved 1mm on both sides i do believe. gsr, b16b and b18cR rods dont have to be shaved.
Old Dec 13, 2005 | 05:15 PM
Default Re: (projectTeG)
ya but he is using pr4 rods
Old Dec 14, 2005 | 07:36 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allinone07860 &raquo;</TD></TR><TR><TD CLASS="quote">ya but he is using pr4 rods </TD></TR></TABLE>
read what i wrote again. you have to shave the rods to fit ITR,pct, or gsr pistons IF they are b16a,b17, or ls rods.
Old Dec 14, 2005 | 11:07 PM
he is trying to LS VTEC U CANT USE any other stock rod to go lsvtec
read it again let it sink in
Old Dec 15, 2005 | 03:28 PM
projectTeG's Avatar
^^yea i wasnt stating that he can use those rods, if you read my first post talking about gsrious's post youll get what i mean. he was saying you only have to shave the rod if they are b16a rods, but that is not fully true because you have to shave pr4/p75, b16a, and b17a rods in order to fit ITR, pct, or gsr pistons. i was no where near saying that he cant or should use different rods.
Old Dec 28, 2005 | 08:57 AM
the.hamburglar's Avatar
what about if you get NPR 82mm itr replicas pistons with a bore then can you use LS rods without having to shave anything?
sik_sol
Sep 24, 2006 05:28 PM
lscoupe
May 18, 2005 02:20 PM
raifordmotors
11
Sep 15, 2004 01:03 PM
