Do you have a Denso or Showa radiator? Dont know....Read This!
Old Dec 8, 2005 | 04:13 PM
Si Integra's Avatar
Default Do you have a Denso or Showa radiator? Dont know....Read This!
After reading all these posts that led me to frustration. I figured I would do my do diligence and post the info I gathered.
I called Koyo this evening and accoeding to them the following will answer your questions!
Denso: (GSR/R)- 13 3/4x 25 3/4 x 21/16
L W H
Showa (LS) Core (L) 13 3/4 x (W) 26 1/8 x (H)2 1/16
End tanks (L) 2 3/8 x (W) 27 1/16 x (H)2 3/8
Inlets/Outlet: 1 1/4
The LS has measurements for the endtanks as well. You will have to do the math to get the ones for the Denso.
Simply put and to end the BS debates floaring around:
GSR/R are strictly Denso
LS are strictly Showa
If you have vice versa, it has been replaced or swapped. Simple as that.
The measurements should help you if you ae customizing things or need this or that as an option.
All fo the above info was curtousy of the nice folks at Koyo
Old Dec 8, 2005 | 04:16 PM
Si Integra's Avatar
FYI- this was confirmed for the following part numbers:
R1741 w/ "showa" radiator
R2028 W/ "denso" radiator
dwn2earth922
Sep 22, 2009 06:34 AM
94HondaAccordEX
Jan 17, 2007 01:28 PM
no2unenolife
Oct 6, 2006 01:22 AM
Malice
Apr 18, 2002 12:12 PM
mikecel79
Apr 11, 2002 10:24 PM
