TODA Flywheel + Turbo
I was thinking getting a TODA Lightened Flywheel now and getting my GReddy Turbo kit after. Would the TODA Flywheel have a chance of cracking with turbo? Or should I stay with a stock flywheel (or R flywheel) to be on the safe side?
how about toda b cams and turbo?
9.5 redline and turbo sounds like it could be alot of fun if it doesnt break anything
lots of valve overlap on a turbo motor
most turbo guys drag race...
if you are drag racing with the turbo you want a heavier flywheel..
it will help your launch with slicks...
if you plan on road racing with it, go ahead and get the flywheel...
hth
-Dan
hth
-Dan
I have toda b and clutchmaster 8lb fly wheels with my turbo b18c1, I'm really suprise of how well the combo works. I autox a lot with the car and turbo lag is minimal. I drag the car once last year just to see how fast the car is. I did 11.80@ 121mph at etown with that setup and got kicked out because I dont have a rollcage in my car
the Toda flywheel will work good with turbo from what I've heard, you might loose a bit off the line but after that the turbo will spool quicker and the revs will fall faster to give you a bit more rpms to work with in each gear. As for using Toda B's with turbo, I dont think that is the smartest thing....
