How to Convert Hondata Stage 2 programming to S100 spec?
Old Dec 8, 2005 | 02:24 PM
GUILOTINE's Avatar
Kill Gil
Default How to Convert Hondata Stage 2 programming to S100 spec?
Ok heres the situtation. I currently have my Integra fully tuned with a P28 with a Hondata Stage 2 but recently acquired a S100 already witha P28. I wish to get rid of the old Stage sytem since Hondata no longer supports it and I have a buyer. I know I can't just swap the chip from my Stage 2 and install it in my S100 because the programming is different
heres the question....
I have access to a Eprom burner...
what changes do i need to do to make this program compatible with my new S100?
Do I need to have both the stage sytem and s100 software to accomplish this?
thanks
Old Dec 8, 2005 | 05:49 PM
onepoint6i's Avatar
Default Re: How to Convert Hondata Stage 2 programming to S100 spec? (GUILOTINE)
w3rd
Old Dec 8, 2005 | 09:30 PM
SilCiv2K's Avatar
one option would be to get the chip out of the ecu and upload the bin from it using your prom burner(assuming you have that option). You can try importing the maps into s100 editor and hopefully the original bin will be compatible with it (s100)- if not you can just copy&paste the maps using Excel or if you got alot of time on your hands you can copy cell by cell but this way you can make sure everything goes where its supposed to.
Old Dec 8, 2005 | 09:32 PM
onepoint6i's Avatar
Default Re: How to Convert Hondata Stage 2 programming to S100 spec? (SilCiv2K)
what he said
Old Dec 8, 2005 | 10:47 PM
GUILOTINE's Avatar
Kill Gil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilCiv2K &raquo;</TD></TR><TR><TD CLASS="quote">one option would be to get the chip out of the ecu and upload the bin from it using your prom burner(assuming you have that option). You can try importing the maps into s100 editor and hopefully the original bin will be compatible with it (s100)- if not you can just copy&paste the maps using Excel or if you got alot of time on your hands you can copy cell by cell but this way you can make sure everything goes where its supposed to. </TD></TR></TABLE>
sounds simple enough, Ill see if my friend can do that
ScottFern
Sep 27, 2003 10:08 PM
AllMotorMark
Aug 26, 2002 07:28 PM
integra1884
May 17, 2002 09:03 AM
