95 accord Timing Chain Cover
Old Dec 8, 2005 | 01:53 PM
RA042426's Avatar
Default 95 accord Timing Chain Cover
Last night my accord dumped about a quart of oil coming from the timing chain cover in the center where the bracket is, so i cleaned up the mess then i dropped a quart back in and no leak anyone know what caused this and will it happen again and is there a way to fix it with out lifting the engine from the bay? P.S. Sorry for so many questions.
Old Dec 8, 2005 | 02:06 PM
Chiovnidca's Avatar
Default Re: 95 accord Timing Chain Cover (sca2face)
I'd check the balancer shaft seal before driving it anymore. Usually when they come out they're out for good though.
Old Dec 8, 2005 | 04:35 PM
SteveoBA8's Avatar
Default Re: 95 accord Timing Chain Cover (Chiovnidca)
You mean your timing BELT cover, either a cam seal or the balance shaft seal. Yes either can be replaced with the engine in the car, might as well do your t-belt, b-belt , w-pump, balance shaft seal retainer( if F series) while your in there. Good luck.
Old Dec 8, 2005 | 08:46 PM
RA042426's Avatar
Thanks guys you are the best, i got 1 more question do you happen to know where i might be able to get the seal from?
Old Dec 8, 2005 | 08:50 PM
deserthonda's Avatar
Default Re: (sca2face)
get it at the dealer , also get a seal retainer ..........if t-belt is oil soaked replace it as well
Old Dec 8, 2005 | 08:52 PM
RA042426's Avatar
10-4 thanks
Old Dec 9, 2005 | 07:20 AM
RA042426's Avatar
Well I tried to do it my self but ran into a little problem so i'm gonna take it to the pros unfortunately i'm gonna have to shell out $$ Thanks for your help thought guys hope you all have a great christmas
masospaghetti
Sep 22, 2014 05:31 AM
freezerman
Jan 8, 2012 04:13 PM
JaMoto
Jul 26, 2007 01:14 PM
i93SE
Dec 4, 2006 11:12 AM
scgtam
Sep 15, 2003 05:19 PM
