94 honda won't turn over.
Old Dec 8, 2005 | 12:34 PM
chubbz's Avatar
Default 94 honda won't turn over.
I have a 94 honda accord the car was driving fine yesterday and now it does not want to turn over. It sound like it want to but doesn't. I checked the wires and battery and they are fine.
Old Dec 8, 2005 | 09:25 PM
deserthonda's Avatar
Default Re: 94 honda won't turn over. (chubbz)
does it make any sound at all?? if battery is ok and cables are tight and not corroded ,it could be the starter ...
Old Dec 9, 2005 | 06:58 AM
nickhans's Avatar
it could be your main relay, i have a 1991 accord and it did this too, it wanted to turn over but it would never want to. good luck
Old Dec 9, 2005 | 07:46 AM
Ross 2.0's Avatar
In a Junkyard near you.
So your saying the motor spins but will not start? Could be a number of things. Get it nice and quiet in your car and turn the key to on (2 clicks) and listen for a click when your check engine light goes off. If there is no click you may have a bad main relay. If there is a click it may be a coil or ignitor.
If it doesn't enven spin be sure you have enough power and good connections. If that's ok you MIGHT have a bad starter.
Old Dec 9, 2005 | 10:56 AM
i wish that people would be more definite in defining WON'T TURN OVER ... does it mean cranks but won't start or doesn't crank at all.. because diagnostic is totally different then...
Old Dec 9, 2005 | 11:17 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">i wish that people would be more definite in defining WON'T TURN OVER ... does it mean cranks but won't start or doesn't crank at all.. because diagnostic is totally different then...</TD></TR></TABLE>
to the OP:
do what MooGoCow3 said and let us know what you come up with.
on a side note, my girls 95 Jimmy just did something similar a week or two ago. Was running fine and then the next day would crank but wouldn't start. That day and the next were raining so I didn't do anything. Then the next day it wasn't raining and the car started up without a problem. So I figured it had to of gotten moister in the ignition system some how, maybe a cracked cap or something. So we replaced the cap, rotor, wires and plugs ( it was due for a tune-up anyway) and now no problems.
Old Dec 13, 2005 | 07:51 PM
chubbz's Avatar
Default Re: (TouringAccord)
SORRY. THE CAR SOUND AND FEELS LIKE IT WANTS TO START BUT IT DOESN'T STARTS FOR A SECOND TH SHUT OFF.
Old Dec 13, 2005 | 09:36 PM
zumiez007's Avatar
Default Re: (chubbz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">So your saying the motor spins but will not start? Could be a number of things. Get it nice and quiet in your car and turn the key to on (2 clicks) and listen for a click when your check engine light goes off. If there is no click you may have a bad main relay. If there is a click it may be a coil or ignitor.
If it doesn't enven spin be sure you have enough power and good connections. If that's ok you MIGHT have a bad starter.</TD></TR></TABLE>
(Maybe it came up invisiable on his computer screen the first time)
Old Dec 14, 2005 | 04:15 AM
H-T Order of Merit
turn off your caps lock. Makes it seem like your yelling. and if you are yelling, you need to calm down a bit.
also, you didn't really answer deserthonda's question. All you did was restate what you said in your first post but in caps.
When you turn the key, does the motor crank and just not fire up.
or...
When you turn the key, does the motor do nothing? No cranking or anything?
Old Dec 17, 2005 | 08:53 AM
chubbz's Avatar
I am not yelling when i turn the key the motor cranks.
Old Dec 18, 2005 | 08:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chubbz &raquo;</TD></TR><TR><TD CLASS="quote">I am not yelling when i turn the key the motor cranks. </TD></TR></TABLE>
if it cranks then it has nothing to do with battery or starter... now you need to diagnose if it is lack of fuel or lack of spark....remove tube that goes to throttle body .....have a friend crank car over, spray some carb cleaner in there if car starts it is lack of fuel........main relay, fuel pump, ( out of gas. yes i have seen that on a few occasions ) ....... if still no start. pull a spark plug wire, hook up a screwdriver to it and ground it have someone crank and see if u get spark ..if no spark,,, could be coil, rotor . cap, ignitor..ignition switch ... try these quick tests and let us know ..
Old Dec 18, 2005 | 04:59 PM
H-T Order of Merit
ok, thank you. Try what desert said and let us know what you come up with.
OT
deserthonda, what happened to your avatar? Did you get in trouble for it or something?
Old Dec 18, 2005 | 08:51 PM
chubbz's Avatar
Thanks will try it out.
Old Dec 18, 2005 | 08:56 PM
chubbz's Avatar
The car is starting up now and it takes a few tries. Before it turns on sound like something is poping then is starts. I have to put my foot on the gas so it could start. It has a strong smell of gas once it starts. Could it be the fuel filter?
Old Dec 18, 2005 | 10:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
OT
deserthonda, what happened to your avatar? Did you get in trouble for it or something?</TD></TR></TABLE>
nope ,, no trouble at all,,, some people were not properly concentrating on the matter at hands ( cars ). .but SHE WILL BE BACK....
Old Dec 19, 2005 | 03:39 AM
H-T Order of Merit
What did you do, other than pressing the gas, to get the car to start? Or did it pretty much just decide to start up now?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">nope ,, no trouble at all,,, some people were not properly concentrating on the matter at hands ( cars ). .but SHE WILL BE BACK.... </TD></TR></TABLE>
ah, lol. Ok, Just wondering. I saw your percent was down and wondered if that was why.
1337knub
Feb 10, 2014 06:57 AM
Connor1432
14
Sep 12, 2012 03:38 PM
joshuahettinger
Jun 26, 2012 09:47 AM
austinkli
Nov 6, 2008 12:28 PM
gruegrimman
Oct 5, 2007 03:04 AM
