A keyed Carbon Fiber hood?
What happens if my carbon fiber hood gets keyed up... is it possible that you can clear that stuff up? cause there are plenty of haters goin around in my city... and im jus wondering if its possible if you can clear up ur hood from all the nasty key damage....
Yes, it is possible to repair it, depending on how deep the damage is. If the carbon fiber cloth is torn you will not be able to make it look the same. If the damage is just in the resin coat then that can be repaired, it's very similar to fiberglass repair, you might take it to a body shop and see what they could do with it.
ahhh i see.... seems like alot of money to get it repaired though... but im assuming its worth it.. dont wanna leave ugly words on my car.. but i suggest that i should just get a very sensitive alarm and watch my car carefully.
resins a cheap repair, i'd think... its just a matter of sanding it down and pouring on a new coat of resin.
torn fibers, i would assume it'd be expensive.
ShinotakuX
Feb 10, 2008 04:15 PM
