84-87 crx mount kit?????
Old Dec 8, 2005 | 11:20 AM
Evil-EK's Avatar
Default 84-87 crx mount kit?????
I need to find a mount kit for a 84-87 crx. We are gonna install a ls in this car and need a mount kit. Anybody know where, who, and how much?
Old Dec 8, 2005 | 11:24 AM
Lamchop0000's Avatar
Default Re: 84-87 crx mount kit????? (BigBlockH22atch)
http://hasport.com/Products/Mo...1.htm
Old Dec 8, 2005 | 11:29 AM
Evil-EK's Avatar
Default Re: 84-87 crx mount kit????? (LamRacing)
I figured hasport made a kit. Do you know if HCp makes a kit?
Old Dec 8, 2005 | 11:35 AM
http://www.google.com
Old Dec 8, 2005 | 11:36 AM
Evil-EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LamRacing &raquo;</TD></TR><TR><TD CLASS="quote">http://www.google.com</TD></TR></TABLE>
Thats funny! LOL
I actually clicked on that expecting all the work to be done! LOL
Old Dec 8, 2005 | 11:38 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch &raquo;</TD></TR><TR><TD CLASS="quote">I figured hasport made a kit. Do you know if HCp makes a kit?</TD></TR></TABLE>
how about checking
here
Old Dec 8, 2005 | 11:57 AM
Evil-EK's Avatar
Default Re: 84-87 crx mount kit????? (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">
how about checking
here</TD></TR></TABLE>
Thats funny. I almost clicked on it but for some reason I just didnt.
Thanks for all your help though.
Old Dec 8, 2005 | 12:01 PM
temp's Avatar
Thanks for all your help though.</TD></TR></TABLE>
HAHAHAHA now use google
Old Dec 8, 2005 | 12:03 PM
Evil-EK's Avatar
Nice to know everybody still has a sense of humor.
Old Dec 8, 2005 | 12:04 PM
DEIVIONCRX's Avatar
Hasport still makes the kit
Place Racing use to make them, the mounts sucked, they always broke, and they went outa buisness
you will need mounts, axles, shift linkage, and alot of wiring
Old Dec 8, 2005 | 12:05 PM
Evil-EK's Avatar
Default Re: 84-87 crx mount kit????? (DEIVIONCRX)
I was searching for the axel combo. Just curious if I could just make a set.
Old Dec 8, 2005 | 12:19 PM
UltimX's Avatar
you are also going to have to do a mpfi conversion aswell unless it's an si. but thats mostly wiring. its really expensive unless u want to weld 1 mount then you don't need the 500 mount kit. just the axles, shift linkage and what not.
Old Dec 8, 2005 | 12:24 PM
Evil-EK's Avatar
Default Re: 84-87 crx mount kit????? (UltimX)
It is an SI thank GOD.
Old Dec 8, 2005 | 02:13 PM
DEIVIONCRX's Avatar
you still will have to convert from vaccum advacne to electronic advance
as far as i know there is no DIY axles for the bseries swap, raxles or hasport for axles
before you bolt the motor in for good, its a good idea to mark where the 2 bolts are on the IACV and then take a hammer and dent the firewall a lil bit so you will be able to get the IACV off later without taking the Intake Mani off
Old Dec 8, 2005 | 02:29 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEIVIONCRX &raquo;</TD></TR><TR><TD CLASS="quote">
before you bolt the motor in for good, its a good idea to mark where the 2 bolts are on the IACV and then take a hammer and dent the firewall a lil bit so you will be able to get the IACV off later without taking the Intake Mani off</TD></TR></TABLE>
no you dont...just let the torque of the motor do that for you.
pm'd
Old Dec 8, 2005 | 02:31 PM
Evil-EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEIVIONCRX &raquo;</TD></TR><TR><TD CLASS="quote">you still will have to convert from vaccum advacne to electronic advance
Thank you for all the info. I have done a lot of swaps but this will be my first 84-87 crx. I am not looking forward to it.
Old Dec 8, 2005 | 02:41 PM
temp's Avatar
Default Re: 84-87 crx mount kit????? (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">
pm'd</TD></TR></TABLE>
HAHAHAHAH $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Old Dec 9, 2005 | 05:00 AM
StorminMatt's Avatar
Speaking of intake manifolds, any idea if a GSR manifold will fit?
Old Dec 9, 2005 | 09:12 AM
vtecn8ive's Avatar
Default Re: 84-87 crx mount kit????? (StorminMatt)
I highly doubt the GSR manifold will fit.
You will need 86-89 integra front steering knuckles
axles (get them from Raxles.com)
wiring (obdo/obd1)
mount kit
Guage cluster will need to be an HF or a hybrid HF/SI in order for vtec to work
*something to do with the speedo
Old Dec 9, 2005 | 11:32 AM
Evil-EK's Avatar
Default Re: 84-87 crx mount kit????? (vtecn8ive)
Not doing a vtec swap. Just a ls. But I appreciate the steering knuckle info!!
Old Dec 9, 2005 | 11:35 AM
vtecn8ive's Avatar
oops sorry forgot you weren't.
then just minus that.
may look into getting a bigger fuel pump but you should be fine with what you got.
http://www.redpepperracing.com in case you didnt know.
Old Dec 9, 2005 | 05:19 PM
DEIVIONCRX's Avatar
GSR will not fit without major modification to the firewall, a aftermarket intake manifold would be reqauired, or a ITR/B16 manifold
Old Dec 9, 2005 | 07:30 PM
vtecn8ive's Avatar
^^ uh? itr/b16 will not just go on gsr different bolt patterns..
skunk2 wiill save you.
brian g
27
Jan 30, 2006 09:13 PM
vuse1
22
Jul 18, 2005 04:26 PM
Lastgsr
Audio / Security / Video
Apr 20, 2004 07:39 PM
jdmitr1982
Feb 9, 2004 07:57 PM
NWAS
17
Apr 4, 2002 06:23 PM
