Which alternator will fit?
Old Dec 8, 2005 | 10:09 AM
goingtobefast's Avatar
Default Which alternator will fit?
I got a 1995 accord LX 4cly.
What alternator from different cars will fit mine? Any civic, integra?
Old Dec 8, 2005 | 10:17 AM
bluskye's Avatar
Default Re: Which alternator will fit? (goingtobefast)
Why are you making it hard? An alternator made for a 1995 accord LX 4cly will work guaranteed.
Old Dec 8, 2005 | 10:26 AM
Default Re: Which alternator will fit? (bluskye)
Because finding the same exact one isn't as easy. I see pletty of used ones from Civic's and integra's around my area locally for cheap. No need in speeding 250dollars for a new one, for a beater car.
Old Dec 8, 2005 | 10:35 AM
bluskye's Avatar
http://www.hondaautomotiveparts.com/
You can cross match part numbers using their parts catalog then. If they match, you in luck. Doesnt autozone sell reman alternators at decent pricing?
Old Dec 8, 2005 | 10:57 AM
Just because the part numbers arne't the same, doesn't mean it wont fit. The part number of a h22 doesn't match my car, but it'll fit it.
Old Dec 8, 2005 | 10:59 AM
AFAccord's Avatar
$250 for a stock alternator?? I didn't pay that much for my 180amp!
Old Dec 8, 2005 | 11:10 AM
bluskye's Avatar
Civic alternator outputs diff electrical characteristics, about 10amps short no? So, even if it did mechanically fit, doesnt meant it will match the correct output.
You can find a reman alternator locally for the accord prolly for $100-$130 after core.
Old Dec 8, 2005 | 11:16 AM
AFAccord's Avatar
In addition, the voltage regulator and plug can be completely different for two alternators with the exact same chassis.
Old Dec 8, 2005 | 02:23 PM
Default Re: Which alternator will fit? (AFAccord)
seriously, if you don't know the answer they reply.
Old Dec 8, 2005 | 04:41 PM
bluskye's Avatar
Um, why you getting pissy? The alternator on the civic doesnt output the same current. So it wont operate at Accord's spec.
Old Dec 8, 2005 | 09:35 PM
Eddiebx's Avatar
dood if ur so dead set on fitting a civic alternator on ur car, then why dont u go and spend some money and time and do so.
why stop there, hell maybe you can find something off a yugo that might fit, and will be cheap too
angrysmileyface
Oct 27, 2013 09:44 AM
sspatriots
Apr 11, 2011 03:29 PM
