CIVIC EF HELP
i have a civic 88 it used to be carburator but i put in a si engine the d16a6 on it i did the wiring good i double check it but everything is looks cool but i got a problem the distributor wont trow any spark at all n i fallow the instructions but the wires are are a diff color from what i see any HELP thanks
1. 88 Civics did NOT come with carburetion. It is hard as hell to switch from it too, a total pain in the ***. You must mean DPFI.
2. Rephrase that question and ill come back later. I cannot understand a word you are saying. "Down in 'da Hood" is not an acceptable language here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic »</TD></TR><TR><TD CLASS="quote">
LOL, punctuation is your friend.
True, no carbs in 88', just DPFI.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tok »</TD></TR><TR><TD CLASS="quote">that aint hood talk mang
http://www.msnbc.msn.com/id/8628930/
http://archives.thedaily.washi....html
The fact that they even entertain this idea disgusts me.
People ask for help on this board and get even mildly offended when I say that I truly cannot understand them. Just speak in plain English and I will be glad to help you out.
</TD></TR></TABLE>http://www.msnbc.msn.com/id/8628930/
whats wrong with a little slang and 'hood talk'? and besides i've seen worse on here.
back to topic.
are your running factory distributor?
not gettin spark?
have you tried to pull out a spark plug wire(from the plug, leave the other end connected to the dist.) and point it on the valve cover nut and have someone crank the car and see if
spark jumps to the bolt?
also check if you got a ground wire runing from the valve cover nut to the radiator support.
replace coil?
cap and rotor?
spark plug wires?
spark plugs?
Modified by LamRacing at 1:48 PM 12/8/2005
back to topic.
not gettin spark?
replace coil?
cap and rotor?
spark plug wires?
spark plugs?
here it goes
the swap is done wiring is done ...
i look it up on the internet how to wire it but my distributor wires look diff from what they say i try it all no spark everyone says is the distributor wiring it cranks but no spark i can take picks if yall can help is a 91 si wiring
untitled
69
Oct 5, 2008 07:38 PM
JDMdc2teg
Jul 2, 2006 10:54 AM
