some help with my gsr mild build
Old Dec 8, 2005 | 08:51 AM
boostd ls's Avatar
Default some help with my gsr mild build
got a eg ahtch with gsr swap looking to rebuild soon just wondering if i put a ls crank and ls rods in it and get the rods shot peened what kinda compression could i safely run on the stock shoot peened rods looking into going with jdm type r (11.6:1) or usdm type r pistons (11.1:1) i am just going to run ctr cams with either omni or type r valve train any info or different ideas will be greatly appreciated also this is a street car that will be driven daily on pump gas thanks
Old Dec 8, 2005 | 09:32 AM
fmrprojects's Avatar
Default Re: some help with my gsr mild build (boostd ls)
that would be a pretty good combo. check out this site to check what your compression will be. they calculate your compression for you. http://www.c-speedracing.com
Old Dec 8, 2005 | 03:01 PM
boostd ls's Avatar
yeah thanks that is were i got the calculations for the compression ratios but my question is are the stock ls rods if i get them shootpeened are they strong enough to hold the 11.6:1 or should i just go with the 11.1:1 compression any extra info would be greatly appreciated thanks
Old Dec 8, 2005 | 04:04 PM
Runnerdown's Avatar
Usdm itr pistons are a nice choice and they are inexpensive. You dont really need to shotpeen the rods just change the bolts out for some arps and make sure you get them resized.
Old Dec 8, 2005 | 05:23 PM
boostd ls's Avatar
where could i get some oversized usdm itr pistons at????
Old Dec 8, 2005 | 05:47 PM
Runnerdown's Avatar
Default Re: (boostd ls)
https://honda-tech.com/zerothread?id=1426478
Old Dec 8, 2005 | 08:15 PM
spooncivic1's Avatar
if you are going to do all that put in some forged pistons/rods
93egSLEEPER
Dec 19, 2009 09:00 PM
jennsGSR
Aug 21, 2006 01:41 PM
Mellowgorilla
Mar 7, 2006 07:38 AM
boostd ls
Dec 7, 2005 08:29 AM
DEL HATCH
Feb 5, 2004 05:31 PM
