Any truth to this??
Basically slapping a K20 head on a H22 block, and make a **** load of NA power.
http://www.k20a.org/forum/show...pp=20
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo9Nut »</TD></TR><TR><TD CLASS="quote">I'm talking about 400 NA HP here.</TD></TR></TABLE>
I wish you the best of luck with that.
I woudl hav eto see it in person to beleive that this is even possible. I mean the H22 head and cam gears are toothed for a BELT whereas the K heads are toothed for a CHAIN. Sooo if you have an H head and a K block (or K head and H bock) then how on earth are you going to keep it in time?
not true, he's mixing up the dyno sheets. Mark had said the k made more power than his h but less torque then posted his dyno which was a full H series.
[QUOTE=xEnderx]I woudl hav eto see it in person to beleive that this is even possible. I mean the H22 head and cam gears are toothed for a BELT whereas the K heads are toothed for a CHAIN. Sooo if you have an H head and a K block (or K head and H bock) then how on earth are you going to keep it in time? [/QUO
It's not that hard to fab up some cam gears for the K head.
FastAllmotorLsVtec
May 1, 2004 08:20 AM
