SRS Light (EG)
Old Dec 8, 2005 | 07:11 AM
TURBOED-TEG's Avatar
Default SRS Light (EG)
I was doing some work around the steering column and decided it might be best for me to unplug the airbag just to be safe. Well now that I am done with the work, I plugged the airbag up but the dash light is on. I have disconnected the battery and ecu but nothing is helping...what can I do to fix the light? It is really annoying so any help would be appreciated.
Thanks
Old Dec 8, 2005 | 08:57 AM
Default Re: SRS Light (TURBOED-TEG)
Bump...
Old Dec 8, 2005 | 09:01 AM
AutoXer's Avatar
So your airbag is hooked up, but you're still getting the light?
Old Dec 8, 2005 | 09:08 AM
Default Re: SRS Light (AutoXer)
That is correct...everything is hooked up, fuses are good....etc. Any ideas?
Old Dec 8, 2005 | 09:21 AM
egyolk's Avatar
are you talking about the Red SRS light?
if so you'd have to tkae out ur dash and behind it there is a small plug that you can take off, its connected by yellow color wires (from what i can recall) and you can take that off. it not for anything but the red SRS light soyea... just unplug it and electrical tape it up or something u'll be fine
Old Dec 8, 2005 | 09:22 AM
egyolk's Avatar
Default Re: SRS Light (Eg Yolk)
btw i have a sparco steeringwheel no airbag, and yes you'll still have to unplug that plug to get rid of the light.
Old Dec 8, 2005 | 09:27 AM
I have the stock steering wheel with the airbag installed...I am not looking to unplug the light...there has to be a way to clear the light. I guess I will contact the dealership or something.
Old Dec 8, 2005 | 09:31 AM
egyolk's Avatar
Default Re: (TURBOED-TEG)
oh man reading pwn3d me lol sorry man u better contact your local dealership lol
Old Dec 8, 2005 | 09:34 AM
its cool...thanks anyways
Old Dec 8, 2005 | 09:38 AM
EeeJayEight's Avatar
did u try disconnecting the battery for a bit...
if that doesnt work take it to the dealer or a local shop and have them scan it...
dont tell them u disconnected it
Old Dec 8, 2005 | 09:42 AM
Default Re: (EeeJayEight)
Battery has been disconnected for many hours before...and I have disconnected the ECU neither cleared the light.
Old Dec 12, 2005 | 07:10 AM
bump...
Any other ideas guys?
Old Dec 12, 2005 | 07:13 AM
JDM-EJ1's Avatar
This should help.
http://www.norcalrcrew.com/index.php?categoryid=13
Old Dec 12, 2005 | 07:22 AM
Brent1's Avatar
i had the same problem. after pulling some fuses the light came on.
if you still want functioning airbags do not disconnect stuff or pull the bulb out. doing that will cause the airbags to not function.
FYI - all yellow wires and connectors are for the sirbags.
Old Dec 12, 2005 | 07:24 AM
JDM-EJ1's Avatar
Default Re: (Brent1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brent1 &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem. after pulling some fuses the light came on.
FYI - all yellow wires and connectors are for the sirbags. </TD></TR></TABLE>
Correct. I replaced my steering wheel with an aftermarket removeable one. My SRS light was on. I then replaced my cluster with a VTi cluster, and those clusters don't have an SRS light.
If the light is on, does the mean your airbag system (in my case, the passengerside one) won't work?
Old Dec 13, 2005 | 03:50 AM
Brent1's Avatar
yes if that light is on, the airbags should not work.
lude98SH
Sep 28, 2008 07:51 PM
19992civichatch
16
Mar 13, 2007 07:38 PM
Caveman74
Nov 5, 2006 05:16 PM
SiR AuToBoT
Apr 5, 2005 05:50 PM
mongoliandonuts
Feb 21, 2005 08:37 PM
