do u really need a block guard for a N/A motor
Old Dec 8, 2005 | 12:50 AM
BlUeHoOdCiViC99's Avatar
Default do u really need a block guard for a N/A motor
trying to get to 200 whp daily driven b18c1 do i really need it meaning the block guard going to be running 11.8 cr std wiseco pistons
Old Dec 8, 2005 | 01:56 AM
Mr.E.G.'s Avatar
Default Re: do u really need a block guard for a N/A motor (BlUeHoOdCiViC99)
are you talking bout the thing that bolts to the bottome end or the thing that gets hammered in between the cylinders and the block
Old Dec 8, 2005 | 05:25 AM
The Weather Man's Avatar
The hammered in thing is the block guard.
No, you don't NEED it - but its cheap and its proven to work.
No hotspots like everyone else says.....get a good one with coolant passages.
Old Dec 8, 2005 | 05:54 AM
b19coupe's Avatar
No. Do not need them and I don't use them. 220 whp daily driver and 250 whp drag car.
Old Dec 8, 2005 | 07:14 PM
Default Re: do u really need a block guard for a N/A motor (b19coupe)
thanks i was doing lots of reading on it stated was that it puts more stress on the sleeves etc so not block guard for me still would like to know wa other people think experiences good or bad
Old Dec 9, 2005 | 05:10 AM
stone_free's Avatar
all motor...not that u cant use it..
turbo application...i would use it if ur not sleeving the block...but thats a whole other story
Old Dec 9, 2005 | 07:50 AM
DA-MAX's Avatar
would there be any exception for a stock sleeved B20 with 12.x:1cr?? or still no need for the guard?
Old Dec 9, 2005 | 09:03 AM
RudeBwaiSi's Avatar
Default Re: (DA-MAX)
For that I would get it, I hear high CR and stock B20 sleeves might be a bad combo. I have 11:1 on my B20 and I have a block guard, it doesn't hurt to do it and they are fairly cheap.
Old Dec 9, 2005 | 09:33 AM
d16dcoe45's Avatar
Default Re: (RudeBwaiSi)
In retrospect I probably would have put one in. The problem with putting it in AFTER your motor is built, is that since its a press fit between the sleeves and the block it could shift the sleeves a tiny amount, thus compromising ring seal. It seems logical--but I have no proof that it actually does this. Anyone else want to chime in?
Old Dec 9, 2005 | 11:09 AM
CHEETAH's Avatar
Default Re: (d16dcoe45)
don;t need it on the stock sleeved b18a/b/c, b16a/b, b17a ... I would recommend it on the b20a/b with very high compression (around 12:1 and up) ...
its just added protection. It does not shift sleeves.
blackccoupe
Oct 14, 2010 10:28 PM
beater1
Aug 1, 2008 05:15 AM
benmyfriend
19
Sep 28, 2006 02:41 PM
CIVICNONVTEC
Aug 23, 2003 06:00 AM
madman604
May 23, 2003 04:19 PM
