Suspension & Brakes Theory, alignment, spring rates....
koni yellow question
Old Dec 7, 2005 | 11:01 PM
streetlights's Avatar
Default koni yellow question
okay...so i first posted this in the appearance forum and have been bumping it up for the last 3-4 days but no one has been able to help me...im wondering if ill have some better luck with ppl in here...here's my original post
I have eibach sportline springs and was wondering if anyone else is using these springs with koni yellows...can you post pics of what your ride height looks like, i have searched through most of the threads and cant really find pictures of cars with lowering spring/koni yellow combos most pics are of ground controls with koni yellows...i wanted to see pics of any cars with a lowering spring/koni yellow combo, but especially pics of dc2's with this combo...thanks alot
if you do post pics...can you specify if your wheels are 15's or 16's...thank you
Old Dec 8, 2005 | 10:45 AM
Default Re: koni yellow question (streetlights)
bump
Old Dec 8, 2005 | 11:00 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetlights &raquo;</TD></TR><TR><TD CLASS="quote">
I have eibach sportline springs and was wondering if anyone else is using these springs with koni yellows...</TD></TR></TABLE>
By changing the shock, it's not going to effect your ride height at all, unless you use the lower spring perch on the Konis.
Old Dec 8, 2005 | 11:26 AM
Default Re: koni yellow question (AutoXer)
yeah...i figured that...i was planning on probably putting the shocks on the lowest perch setting...i was just wondering how much lower my car would be on the lowest setting with the sportlines...
Old Dec 8, 2005 | 11:38 AM
EK k kay's Avatar
The distance between the current circlip groove you are using and the groove you are going to use will be the height difference. The bottom setting of my front Koni Yellows slammed my car when I had H&R Sport springs. You aren't supposed to use the height settings with aftermarket springs though.
Old Dec 8, 2005 | 04:47 PM
Default Re: koni yellow question (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote"> You aren't supposed to use the height settings with aftermarket springs though.</TD></TR></TABLE>
i was under the impression that the yellows had three different settings...youre telling me that youre not supposed to use the bottom (lowest) setting if i have aftermarket springs??am i supposed to keep it on the middle one??...also why cant you put it on the lowest setting? thanks for the help
Old Dec 8, 2005 | 07:30 PM
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetlights &raquo;</TD></TR><TR><TD CLASS="quote">i was under the impression that the yellows had three different settings...</TD></TR></TABLE>
Fronts = 2 settings (stock and lower), Rears = 3 setting (higher, stock and lower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetlights &raquo;</TD></TR><TR><TD CLASS="quote">youre telling me that youre not supposed to use the bottom (lowest) setting if i have aftermarket springs??</TD></TR></TABLE>
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetlights &raquo;</TD></TR><TR><TD CLASS="quote">am i supposed to keep it on the middle one??...</TD></TR></TABLE>
Upper on front, middle on rear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetlights &raquo;</TD></TR><TR><TD CLASS="quote">also why cant you put it on the lowest setting?</TD></TR></TABLE>
The alternate grooves are made to lower or raise the car with stock springs. If you lower the car with the perch (25mm front/15mm rear) and with lowering springs you will get a cumulative lowering from both the car will be effectively lowered too far with insufficient spring rate. At that point, I would expect the car is going to be living on the bump stops unless you wrongly remove them.
Old Dec 8, 2005 | 08:19 PM
Default Re: koni yellow question (CRX Lee)
so if i keep the perches on the upper for the front...and middle for the rear would my car be any lower than it is now??by the way...thanks for your help...it would still be nice to see pics
Old Dec 9, 2005 | 05:32 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetlights &raquo;</TD></TR><TR><TD CLASS="quote">so if i keep the perches on the upper for the front...and middle for the rear would my car be any lower than it is now??</TD></TR></TABLE>
No, it will be at the same height as it is now; those are the 'stock' perches.
Old Dec 9, 2005 | 07:07 AM
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">No, it will be at the same height as it is now; those are the 'stock' perches.</TD></TR></TABLE>
What he said.
Old Dec 9, 2005 | 07:33 AM
94eg!'s Avatar
#1 Super Guy
Loved
The lower perch is only for the use of "stock" springs. The only other time they are used is for ground control coil-overs...
Here is a pic of the cir-clip in the upper location. For more pics check out the "Koni shock install" thread at the top of the susupension forum...
Old Dec 9, 2005 | 10:23 AM
EK k kay's Avatar
Default Re: koni yellow question (94eg!)
^ Three suspension gurus, one right after the other...wow
Old Dec 9, 2005 | 10:32 AM
thanks for all of your help...i really appreciate it
ThaLost0ne
Feb 13, 2006 12:01 PM
streetlights
Dec 13, 2005 07:35 PM
Understeer
Mar 7, 2005 10:18 AM
Aaron.
Nov 13, 2002 07:52 PM
wakaru
Apr 2, 2002 07:08 PM
